Thread: Coolant Leak
Results 1 to 7 of 7
  1. #1 Coolant Leak
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    So my cars been dripping coolant, I've looked everywhere I could and can't find the direct source, but my guess would be the water pump. My concern is if any of the coolant is leaking into the engine? Are there any signs other than taking the oil cap off and looking for a milky mixture in the valve cover?
    1998 Grand Prix GTP Daytona - CAI, XP Cam, Iceman tune, Speed Daddy Headers, 3.2 in pulley, Ported blower, Al 103's, 3in Catless DP, Transgo "shift kit", No resonator to Magnaflow Mufflers. 93K Miles
  2. #2 Re: Coolant Leak
    Dec 2012
    Where 4T65E's were born
    If you pull the dipstick after it's been running, and there's no foam on it, there's no water/coolant in the engine. When the engine is cool enough, reach your hand down by the water pump and lower coolant elbow and feel for any coolant. Also check the heater hoses that are just behind the alternator, and check the lower rad hose. I say feel for it because you really can't see down there. Assuming it's dripping on the passenger side.
    Sold.
  3. #3 Re: Coolant Leak
    Nov 2011
    Indiana
    Its is I've lifted it at my house and checked, at the lifts at my works garage and couldnt find the source. Somewhere around the water pump and power steering. From the top view, I couldn't see anything. Hoses seem fine and all. So when pulling the dipstick, after the cars been running, it should look like what exactly?
  4. #4 Re: Coolant Leak
    Dec 2012
    Quote Originally Posted by JDrach View Post
    Just oil. It's okay if there are tiny bubbles if it was just running, but it has to be the same color as oil.
    The level won't be accurate until it's sat for at least 10 minutes after being fully warmed up. If it's sat overnight and not started yet, that's the best time to check it.
    Sold.
  5. #5 Re: Coolant Leak
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    is the water getting on the crank pulley or is it on top of the water pump?
    Poly Uppers, 3.5 snout, HAI, Can Tune, STB, Autolite 606 coppers, 2.5 cattless dp
  6. #6 Re: Coolant Leak
    Nov 2011
    Indiana
    here are the best pics i could go of it from underneath.
    http://s1139.photobucket.com/user/drach30/media/02854017-2E4D-4C37-B40B-755A72812B1E-1359-000000C9472592D7_zps16366535.jpg.html?sort=3&o=1
    It seems to be dripping from a source higher than the drops show. I cant find the source and had someone else look at it and couldn't find it.
  7. #7 Re: Coolant Leak
    could be the lower elbow leaking, and that would be why you can see it so good.
    car off, you can stick your fingers along the pipe in the alt bracket towards the engine block and the lower elbow, and feel for moisture that way.
    the water pump, grab its pulley with 2 hands, push one side while pulling the other, then back and fourth, if it moves its on its way out. and could be the leak.
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. Coolant Leak
    By Thenerveman in forum General Tech Discussion
    Last Post: 08-01-2013, 06:45 AM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. Bad coolant leak** Need help...
    By 3R1CD4V15 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-30-2012, 04:20 PM
  5. Coolant Leak
    By rippemblue2005 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2010, 11:30 AM
