Thread: Thinking of converting to E85.. Yes or Ne??
Page 3 of 12 FirstFirst 12345 ... LastLast
Results 41 to 60 of 224
  1. #41 Re: Thinking of converting to E85.. Yes or Ne??
    GTX Level Member crbquist's Avatar
    Massachusetts
    Quote Originally Posted by tms8582 View Post
    I've never heard that a stock chain is stronger than a roller chain and have a hard time believing that 90 lb springs are harder on a timing chain than 105's but I've also never scene any actual evidence to say either way. Rollmaster claims otherwise however... Good luck with your e85 conversion
    I could be mistaken, but I always read that 90's were harder on the chain/dampener than 105's due to the ramp rate.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  2. #42 Re: Thinking of converting to E85.. Yes or Ne??
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    Quote Originally Posted by SnowFlake View Post
    I think the ~600hp and relentless beatings had something to do with it lol
    its hard not to beat it. bahahaha
  3. #43 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    Well I filled her up with E85 on Wednesday and have been grandma pedaling for the past few days. I want to run a full tank of the stuff before getting a tune. The car runs fine with it untuned.. no boost of course
    Snowflake is going to give me a real tune next Wednesday, in which I will be on my 2nd tank of E85 so hopefully all the 93 crap is out!
  4. #44 Re: Thinking of converting to E85.. Yes or Ne??
    GTP Level Member tms8582's Avatar
    Washington Michigan
    You bringing smaller pulleys and belts with you? Im sure you will be impressed after your tune
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  5. #45 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    Nah I'm going to stick with a 3.0 pulley for now and see how much timing I can run. If all goes well, I may drop to a 2.8 down the road.
  6. #46 Re: Thinking of converting to E85.. Yes or Ne??
    Washington Michigan
    Yeah with your more efficient GenV and N* that's a smart move. Post back Wednesday and let us know how it goes.
  7. #47 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    Should be very safe on a 3.0 with e85 (more like e70 here though)
    Actually, when I was running the TVS setup, my "e85" was tested at e60.
    Still way better than 93.
  8. #48 Re: Thinking of converting to E85.. Yes or Ne??
    Washington Michigan
    In Michigan they claim it's true e85 only in late July and August... but I guess without testing who knows if it's even 85% then???
  9. #49 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    Shouldn't it be E85 since it is not winter yet? The pump stated E85 so I sure hope it is correct!
  10. #50 Re: Thinking of converting to E85.. Yes or Ne??
    Jul 2011
    CT
    dont be a *****. put the 2.8 on
  11. #51 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    Quote Originally Posted by danomite02 View Post
    Probably will after the winter.
  12. #52 Re: Thinking of converting to E85.. Yes or Ne??
    Chris.. I have a 2.6 if you'd like to try it out.
  13. #53 Re: Thinking of converting to E85.. Yes or Ne??
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    01 Silvermist GTP - Stock trans, ZZP headers, S1X cam, ported heads, phenolic IC, polished Gen V, N*/LQ4, 3.0 pulley, 60# injectors
    If this is the car that's running E85 now you should easily be on a 2.6
    SIX, TOGS, stock heads, GenV, no IC and I DD the car on a 2.8 with 22* of timing.
    Stock trans on the other hand....LOL
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  14. #54 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    Well, things did not go so according to plan today. After doing some WOT runs, my AFR kept going from mid-11's to almost a 13.0 come shift point, meaning the car was losing pressure somehow. No KR until 3rd gear on 18* timing however.. I was totally baffled by this, so we popped the hood and Nick spotted a HUGE kink in the feeding fuel line. The kink was so bad we initially thought the line needed to be replaced. I ended up driving it back home, then popped the kink out with some pliers in under two min LOL. I then did some WOT pulls and the AFR is much more consistent now, however it is still leaning out to about a 12.3-12.4 after 6000rpms. So all in all at least ONE problem was resolved... Now I need to figure out why the AFR is still leaning out a bit. I know mid-12's isn't too bad, I just don't want to give it a more aggressive tune until I figure this out. The car has a racetronix fuel pump/rewire, flex fuel filter from an 04 Mercury Tahoe, and Seimens 65# injectors. Pretty sure I have all the hi-flow fuel needs, which leads me to believe the car is still losing pressure somehow from another kink somewhere or something alike. The tune is safe for now though... Stock timing, however still feels faster than when on 93
  15. #55 Re: Thinking of converting to E85.. Yes or Ne??
    Washington Michigan
    How old is the filter? Is the tank metal? I've heard that filters can plug real quick when converting to e85 especially with a metal tank. My tank is plastic and I changed the filter a week or so after my convert and tune and it was totally clean. In my case it was good to be safe rather than sorry. If your filter is old and your tank is metal I'd change that filer asap. e85 will clean a metal tank really quick and the particles will get plugged in your filter.
  16. #56 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    Pretty sure all the 00 and up tanks are plastic... I changed the fuel filter a few months ago to on 04 Mercury Tahoe Flex Fuel filter from Autozone.
  17. #57 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    Wish I could Bill, but better safe than sorry! haha
  18. #58 Re: Thinking of converting to E85.. Yes or Ne??
    Washington Michigan
    I'd check the filter and see if its plugged. really
  19. #59 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    I just relocated my pump rewire from the fuse box to the back of the alternator.. Gonna see if that helps or not. Maybe some higher voltage..
  20. #60 Re: Thinking of converting to E85.. Yes or Ne??
    Washington Michigan
    My friends 01 Gtp Daytona 500 has a metal tank btw. Just sayin check it out
  1. converting
    By cmn36 in forum General Tech Discussion
    Last Post: 01-15-2011, 07:18 PM
  2. converting a 01 to an 04
    By sasquatch094 in forum General Tech Discussion
    Last Post: 03-25-2010, 05:22 PM
  3. Converting to supercharged
    By Bechtel88 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2010, 09:31 AM
  4. question on converting.
    By gt42lst in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2009, 11:54 AM
  5. Converting from a 1 bar to a 2 bar map.
    By TurboKent in forum General Tech Discussion
    Last Post: 03-16-2008, 02:10 PM
