Thread: Thinking of converting to E85.. Yes or Ne??
Page 2 of 12 FirstFirst 1234 ... LastLast
Results 21 to 40 of 224
  1. #21
    GTX Level Member crbquist's Avatar
    Massachusetts
    Well I'm doing it! Just ordered 3 high quality gas cans off Amazon haha. I drove to the E85 station today to pick their brain a bit. I asked how long they've had it, how it sells, if they ever sell out, etc.
    They've had it for 4 years and it sells very well. The clerk said a lot of Subaru guys often travel to get it and fill up gas cans LOL. Overall, the commute took me about 35 min each way.. 90% highway. Not too shabby..
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  2. #22 Re: Thinking of converting to E85.. Yes or Ne??
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Quote Originally Posted by crbquist View Post
    Like!
  3. #23 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    Hopefully my 115K L67 bottom end doesn't go boom.
  4. #24 Re: Thinking of converting to E85.. Yes or Ne??
    Mercer, Pa
    How many bottom end failures have you heard about? Rod/piston failures come from to much knock.
    Failure points are in the tranny. You will break stock tranny parts like input shaft or chain before bottom end.
  5. #25 Re: Thinking of converting to E85.. Yes or Ne??
    Washington Michigan
    Yeah usually bottom ends go on rebuilt motors for some reason. Stock blocks are pretty strong and another 40 or 50 hp should not be a problem for your motor. A good tune on e85 should result in little to no knock. One thing to keep in mind is that cold weather e85 is actually a different blend and not true e85. Cold weather "e85" has less ethanol. I don't remember if crbquist mentioned if he would be driving in cold weather or not.
  6. #26 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    Quote Originally Posted by tms8582 View Post
    I don't drive it much in the winter.. Maybe a few miles here and there to keep it moving, but that's about it.
  7. #27 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    Incompetent builders.
  8. #28 Re: Thinking of converting to E85.. Yes or Ne??
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    "knock on wood" I'm still on stock bottom end
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  9. #29 Re: Thinking of converting to E85.. Yes or Ne??
    Feb 2009
    flintnasty MI
    The bottom end might be worried if you are up over 800whp.. even then I probably wont be too worried if you are shifting under 7k.
  10. #30 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    Another concern is that I run a stock timing and dampener..
  11. #31 Re: Thinking of converting to E85.. Yes or Ne??
    Washington Michigan
    New stock timing chain? What # springs?
  12. #32 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    Yes, it was replaced along with the tensioner about 10k miles ago when I did my cam swap. 105 springs.
  13. #33 Re: Thinking of converting to E85.. Yes or Ne??
    Washington Michigan
    You probably should have installed a roller timing chain with your cam and 105 springs but your stock chain is new which helps. I don't think at this point the extra hp you will gain with e85 will make a difference on the timing chain. I think the 105 springs will stress your chain the same with 93 or with e85.
  14. #34 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    I was originally gonna go roller, but was told by many members here that a stock chain would be more than fine for my setup. I was thinking that the extra hp would stress the chain.
  15. #35 Re: Thinking of converting to E85.. Yes or Ne??
    Washington Michigan
    I've read that general rule of thumb is stock chain for rockers and 90 lb. springs, single roller for mild cam and 105 springs, double roller for big cam and 130 springs. Its the springs that stress the chain but im sure you will be fine with your set up for a while.
  16. #36 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    Some say a stock chain is better than a single roller. Also, 90 springs are harder on the chain than 105s because of the ramp rate. I'm thinking I'll be just dandy. But then again, ya never know... Danomite just snapped his single roller yesterday..
  17. #37 Re: Thinking of converting to E85.. Yes or Ne??
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    i just snapped my single roller with my xp and 105s......... and a t70 lol what did i do wrong? hahahhaa
  18. #38 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    Quote Originally Posted by danomite02 View Post
    Yeah, I think the T70 may of had something to do with it..
  19. #39 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    I think the ~600hp and relentless beatings had something to do with it lol
  20. #40 Re: Thinking of converting to E85.. Yes or Ne??
    Washington Michigan
    I've never heard that a stock chain is stronger than a roller chain and have a hard time believing that 90 lb springs are harder on a timing chain than 105's but I've also never scene any actual evidence to say either way. Rollmaster claims otherwise however... Good luck with your e85 conversion
  1. converting
    By cmn36 in forum General Tech Discussion
    Last Post: 01-15-2011, 07:18 PM
  2. converting a 01 to an 04
    By sasquatch094 in forum General Tech Discussion
    Last Post: 03-25-2010, 05:22 PM
  3. Converting to supercharged
    By Bechtel88 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2010, 09:31 AM
  4. question on converting.
    By gt42lst in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2009, 11:54 AM
  5. Converting from a 1 bar to a 2 bar map.
    By TurboKent in forum General Tech Discussion
    Last Post: 03-16-2008, 02:10 PM
