Thread: Sunroof Leak?
Results 1 to 2 of 2
  1. #1 Sunroof Leak?
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    Have read through about everything I can find on the subject, but still looking for more help. 98 GTP , Headliner on drivers side wet and water on floorboard. Front vent tubes are clear of debris, and windshield seal looks good. Not sure where else to look
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  2. #2 Re: Sunroof Leak?
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    I've seen the vent tubes pull off from the sunroof assembly. you lowered the roof liner and did a visual at the A pillars?
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
