Thread: 95 gtp. no crank
Results 1 to 4 of 4
  1. #1 95 gtp. no crank
    Oct 2011
    ohio
    hi guys. in the need of some help. I have a 1995 gtp 3.4. drove to work and have no start to come home. batt. checks good and full charge. replaced starter and cleaned positive cable at that time. dash lights stay on but radio goes out when trying to start. headlamps don't dim in crank position. will start by jumping starter terminals. for about 2 seconds then shuts down. don't want to start changing parts till I no what it needs. thanks for any info.
  2. #2 Re: 95 gtp. no crank
    ignition relay maybe. not sure if your year has a ignition harness issues or not.
  3. #3 Re: 95 gtp. no crank
    Oct 2011
    ohio
    where would ignition relay be located. and does that control cranking
  4. #4 Re: 95 gtp. no crank
    on the newer cars it does. its the harness from the key to under the dash in the 97 and up cars. try looking up one for your year.
    it can also mess with the heater/a/c blower and lights.
  1. No crank, just click. Replaced starter, still no crank.. help!!
    By Steve98GTP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-17-2013, 08:48 PM
  2. No crank. Replaced starter, still no crank. Now what.
    By suctoes in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-13-2013, 01:22 AM
  3. 3 wire crank sensor vs 2 wire with 24x crank trigger
    By greenmachinegtp in forum PCM Tuning
    Last Post: 03-12-2012, 05:45 PM
  4. '98 GT 3.8 won't crank
    By Avant Sport in forum General Tech Discussion
    Last Post: 02-14-2012, 08:40 AM
  5. Crank key
    By Enzo354 in forum General Tech Discussion
    Last Post: 10-26-2010, 03:45 PM
