Thread: Possible reason heat doesnt work? Need opinions.
Results 1 to 2 of 2
m0ng00se Possible reason heat doesnt... 11-23-2008, 12:33 PM
Sabrewings Re: Possible reason heat... 11-23-2008, 12:57 PM
  1. #1 Possible reason heat doesnt work? Need opinions.
    SE Level Member m0ng00se's Avatar
    Jul 2008
    BFE, Kentucky
    Okay, so today i was in the process of replacing my heater core when i discovered a possible reason my heat may not be working....
    When i took out the glove box, i looked at the blower motor assembly and saw that the little sliding door thing above it was open. I could stick my hand down into the blower motor.
    I thought this door was supposed to stay closed. So i went to close it and found it is broken. The door is just sittin in there loosely.
    Would this door being open result in not feeling any heat through my vents? What is the name of this part and can i/where would i buy another one?
    Really would like some opinions since im right in the middle of replacing a heater core that i may not even need to replace, it seems.
  2. #2 Re: Possible reason heat doesnt work? Need opinions.
    Barksdale AFB, LA
    You talking about the recirculate door? My heat works whether I set it to recirculate or not. Usually recirculate is just for the initial warm up of the cabin, then you set it to fresh air to maintain the proper temperature.
    Easy test of your heater core is to warm up the engine and feel the heater hoses. If one is much hotter than the other, it's clogged.
    2009 Subaru Impreza WRX STI
  1. car sometimes starts/sometimes doesnt
    By 98gpgtp in forum General Tech Discussion
    Last Post: 11-05-2008, 12:29 AM
  2. Heating Doesnt Work After Engine Replacement
    By m0ng00se in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-16-2008, 07:06 PM
  3. A pretty good reason why not to street race.
    By ryangtp89 in forum Track Sessions and Kills
    Last Post: 09-29-2008, 06:32 PM
  4. Main reason for Amp to cut Out
    By jacobmh27 in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2008, 09:57 AM
  5. happy just doesnt cut it
    By NKYspdemon in forum Off Topic Discussion
    Last Post: 06-27-2008, 01:55 PM
