Thread: Can someone in the Boise, ID help me fix my coolant elbow on a 2000 Grand Prix GTP?
Results 1 to 5 of 5
  1. #1 Can someone in the Boise, ID help me fix my coolant elbow on a 2000 Grand Prix GTP?
    Sep 2013
    Boise, ID
    I'm not sure if this is the right forum for this but I need the coolant elbows on my 2000 Grand Prix GTP changed. I live in Boise, ID. I've checked a couple of shops and they want close to $300 and from what I've been reading here it's pretty much a 30 minute to 3 hour job depending on experience. So is there someone in this area that can help me out? I will pay you well. Thank you!
  2. #2 Re: Can someone in the Boise, ID help me fix my coolant elbow on a 2000 Grand Prix GT
    Sep 2013
    Syracuse NY
    Hey man not sure about the fwd elbow change but on my rwd 3.8 camaro it wasn't bad at all. Gives you great experience in getting familiar with the car.
  3. #3 Re: Can someone in the Boise, ID help me fix my coolant elbow on a 2000 Grand Prix GT
    Quote Originally Posted by Ibanezz View Post
    It's just a matter of removing the belts, take off the alt and remove the tensioner then replace the elbows. You don't need to pay someone to do that do it yourself.
    04 Comp G.
  4. #4 Re: Can someone in the Boise, ID help me fix my coolant elbow on a 2000 Grand Prix GT
    Sep 2013
    Syracuse NY
    Then it is exactly the same. Except easier on rwd do yourself a favor and buy the metal elbows, will never have to worry about them again. And I used a little rtv on the elbows upon installation. And took the opportunity to paint my alternator and tensioner assembly while it was out.
  5. #5 Re: Can someone in the Boise, ID help me fix my coolant elbow on a 2000 Grand Prix GT
    Aug 2013
    mpls, mn
    You have some tools? Socket set? Easy to find info online or use all data at library. Plastic elbows break off inside casting so digging out old bits is hard. Use some scuff pad to clean crud out of ports.
  1. Bad coolant elbow
    By Shoggy24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2013, 06:11 PM
  2. 2000 Grand Prix coolant leak
    By Rjsleeper in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-03-2013, 12:04 PM
  3. Coolant leak behind power steering box - 2000 Grand Prix V8
    By wcoughlin in forum Introductions/Noob Questions
    Last Post: 10-09-2012, 08:46 PM
  4. Coolant Elbow...AGAIN!!!
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2011, 06:32 PM
