I have been killing myself trying to find an answer , so i figured i would come to the guru's for some help .
car:
95 grand prix SE , 3100
problem:
started about a year and a half ago having the problems . When i turn the ignition on , all lights come on , fuel pump starts , everything is fine until i turn the key . Once i turn the key , all i get is a single click , sometimes . Sometimes it fires right up like there is no problem whatsoever . Other times i have to turn the key several times to get it to finally turn over . This has been getting worse lately and am afraid of being stranded somewhere when it finally decides not to start.
replaced items:
starter , battery , neutral/park switch , new key (thinking it might have been worn resistor pellet but security light does not flash)
other known odd problems:
reverse lights do not work , trunk release in glove box doesn't work
thinking of putting in a switch to the starter from the battery to see if that will work , but figured i would come here first.
any help would be much appreciated !!
