Thread: 1997 GTP starts every time...for five seconds
Results 1 to 7 of 7
  1. #1 1997 GTP starts every time...for five seconds
    Donating Users
    Hi folks-
    I'm having an annoying issue with my '97 GTP. As it says in the thread title, the car starts first time every time and runs just fine, but only for five to ten seconds. After that, it just winds back down to zero RPM - no sputtering, no noises, no drama; it just shuts off as if I'd turned the key. It runs longer if the throttle is open but not nearly long enough to be useful. What's stranger is that this seems to have happened literally overnight: I drove the car home with no incident or trouble, and this behavior started when I went to leave the next morning. There's plenty of gas in the tank, all the lights and accessories come on so it's not the battery, and since the little running it does sounds normal I doubt there's anything wrong with the motor itself. My initial guess is part of the fuel delivery system (e.g. pump, filter, pressure regulator, etc.) but I don't know how or where to begin diagnosing.
    Any thoughts? Thanks for your time.
  2. #2 Re: 1997 GTP starts every time...for five seconds
    Bypass the fuel pump resistor
  3. #3 Re: 1997 GTP starts every time...for five seconds
    Donating Users
    Thanks for the reply. Could you be more specific? I know my way around tools and electronic systems (four years as a service technician at an arcade/hotel resort) but I haven't applied that knowledge to the car very often.
  4. #4 Re: 1997 GTP starts every time...for five seconds
    Donating Users
    Nevermind, I found the procedure in the "Similar Threads" box below. I searched before posting but I didn't find any of those threads. I'll report back on whether it works. Thanks for pointing me in the right direction!
  5. #5 Re: 1997 GTP starts every time...for five seconds
    St. Louis
    Just search in the S/C forum for fuel pump resistor bypass. It should come up. IIRC, you remove relay 15 (under the hood) and bend tab 85 so it doesn't make contact and plug the relay back in. Should set the fuel pump into high speed mode permanetly, bypassing the resistor that has failed.
  6. #6 Re: 1997 GTP starts every time...for five seconds
    May 2013
    lynn mass
    my 00 lumina did the same thing would run for 5 -10 seconds was the fuel pump dealer wanted to charge 1grand cuz it is in the gas tank but a local shop did it for 599.00 so shop around!
  7. #7 Re: 1997 GTP starts every time...for five seconds
    If that works you can run it like that for a long time
  1. 1997 GTP starts then stalls 3 seconds later. Ignition Switch Replacement---SOLVED!!!
    By jeremyaudio in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2012, 01:12 PM
  2. Car starts 3-4 seconds and shuts off. P0122 and P1122
    By Brooks in forum General Tech Discussion
    Last Post: 08-28-2012, 07:47 PM
  3. Cars starts then within seconds DIES!
    By MistyChameleon in forum General Tech Discussion
    Last Post: 07-15-2011, 03:34 PM
  4. GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    By 93Chewbacca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2011, 09:38 PM
  5. Car starts but stalls after 2 seconds
    By cartooz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2009, 06:18 AM
