Thread: P0102
Results 1 to 16 of 16
  1. #1 P0102
    GT Level Member GPTAFan's Avatar
    Sep 2012
    Maryville, Illinois
    02 Gp Gt 142kmiles.
    My car has his maf code, I cleaned the maf didn't work. Swappped 2 difmaf. Didnt Work. It itl, idle rough for a few mins. Then dies bak to normal after a little with an occasional hiccup. My traans is going out. But it runs normal unless I decide to get on it orim goinup a hill riding between 45-50mph then it'll start boggin unless Iet it stayi 3rd. Shifts between 2500-3100rpms normally. Ahyways bak to the code. I changed my ttb gasket cuz there was a gap between thetb and the uim in a spot. But I cnt feel any airleaks. At all. The gap is still there I plan on combining the tb gssket with rtv for a failsafe. My idle sounds like a v8 imo and my friend thinks so as well. Could it be my cat or egr.? I took my air box out cuz it leaked nd now it has the spectre hai. Started it. Cel was gone. Letit run for a few mins. Shutit off. Came back. Started it to my friend., a min after running CEL came right back on. What else can it be
  2. #2 Re: P0102
    Check the wiring to the maf.
  3. #3 Re: P0102
    Sep 2012
    Maryville, Illinois
    Me and my brother did. It all looks good. No kinks or anything.
  4. #4 Re: P0102
    Check your fuse under the hood. It's IGN or something like that.
  5. #5 Re: P0102
    Sep 2012
    Maryville, Illinois
    I'll do that tomorrow. Nd chek bak in.
  6. #6 Re: P0102
    Jan 2012
    Philadelphia
    I got the same code and similar problems still trying to figure it out
  7. #7 Re: P0102
    Sep 2012
    Maryville, Illinois
    Quote Originally Posted by gtpeddie View Post
    I saww. I've had the code for a while. Always assumed it was my maf. And didn't carem my gss mileage never went bellow 20. So it didmt seem like my mpgs suffered. From wat I've read tho.. I might have a clogged cat. But my cel doesn't flash..
  8. #8 Re: P0102
    Sep 2012
    Maryville, Illinois
    And since I have a cel on.. I fail emissions and my plates expired. So I've been riding dirty for a while now
    ..I made the 06 look like 08 so if a co p looks from a distanc http look like I gt till the end of august..lol
  9. #9 Re: P0102
    Sep 2012
    Maryville, Illinois
    Checked it. Looked rough.. couldn't tell if it was bad or not.but replaced with a spare to be safe. Light didn't go away, but it seemed to start better.. lol
  10. #10 Re: P0102
    May 2012
    Albuquerque, NM
    Quote Originally Posted by GPTAFan View Post
    I'll assume you already know this but I'll say it just in case you don't, falsifying or altering government issued identification is much worse than the petty misdemeanor of expired plates. I'd just run expired instead of altering them. Bad bad juju there...
  11. #11 Re: P0102
    Sep 2012
    Maryville, Illinois
    Yess I knoww. Lol I I didn't have a problem so farr. My mom came home wit temp plates today. So I put that on.
  12. #12 Re: P0102
    May 2012
    Albuquerque, NM
    Just trying to help a fellow out.
    Still interested in what is causing the issue. Keep us updated!
  13. #13 Re: P0102
    Sep 2012
    Maryville, Illinois
    Quote Originally Posted by slimguns View Post
    Still haven't figured it out.. since thelight was off for a little I have a few sensors to switcharound to see if the light goes off again.. I'll do that later. I've been busy hanging with a girl the past week.
  14. #14 Re: P0102
    Sep 2012
    Maryville, Illinois
    Almost possitive I have a clogged cat... at idle my exhaust feels like someone blowing hot air with there mouth wide open..only rlly hott
  15. #15 Re: P0102
    GT Level Member 40th GP's Avatar
    Utah
    What ever happened with this?
  16. #16 Re: P0102
    Sep 2012
    Maryville, Illinois
    The right muffler might be clogged.. idk my right tip doesn't flow as good as my left. But I haven't gone any further than that. Been working.. I have gaskets all way down to LIM and a new UIM from zzp. Just.. finding time to do it.. and I wanna make sure I have it all covered and ready to do..cuz I usually dmt have much time between work the girl. And I need to get 2 new tires. Lol
    Ultimatly. Not solved. Yet
  1. code p0102
    By 98pont in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2013, 05:36 AM
  2. p0102 code help
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2012, 06:47 PM
  3. P0102 need help after change!
    By biggt in forum General Tech Discussion
    Last Post: 08-29-2011, 11:46 PM
  4. p0443 and p0102
    By Lawngoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2010, 03:21 PM
  5. code p0102
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2008, 12:09 PM
