Thread: new mods with knock or no?
Results 1 to 2 of 2
  1. #1 new mods with knock or no?
    Donating Users
    Plainfield, IL
    so by spring i will have a 3.4 pulley, intense PCM, TDC racing FWI, APP 104's, and 180 tstat will i have knock? ill have a scanner to see if i am getting knock...if i do get knock will a downpipe, tb shield and spacer eliminate it? also when i get my pcm tuned how many degrees of timing should i have them add? they say up to 3 with 93 octane.....but they offer one and two also? whats a good choice im not so sure how timing/knock coincide but just some real tech info would be nice soo lemme know what you guys think alright...
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: new mods with knock or no?
    Oklahoma
    I closed/locked this thread per the rules here:
    http://www.grandprixforums.net/f14/a...ad-6828-2.html
    Technically, under those rules the thread should have been deleted but your re-posted in the same section again so I thought it better that you see that posted in the wrong area.
    Try posting up in the Tech Lounge since your post is a mix of tuning and engine info.
  1. Knock Knock - What is it?
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2009, 12:28 AM
  2. knock sensor?
    Last Post: 10-20-2008, 12:19 AM
  3. Very informative - mostly on Knock
    By 04CompG in forum General Tech Discussion
    Last Post: 09-06-2008, 01:20 AM
  4. Do I have Engine knock?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2008, 07:59 AM
  5. Bad EGR = knock?
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-31-2008, 07:13 PM
