Thread: Bizarre issue with key fob (Tried ALL obvious fixes)
Results 1 to 2 of 2
  1. #1 Bizarre issue with key fob (Tried ALL obvious fixes)
    Donating Users
    Jan 2013
    Huntsville, AL
    Hi all,
    I'm experiencing a strange issue with my key fob and would appreciate any advice.
    Problem:
    Trunk release key fob button almost always works, horn/panic key fob button almost always works, but unlock/lock buttons barely ever work, with the lock working about 1 in 15 times and unlock working about 1 in 60 times.
    What I've tried:
    -brand new correct CR2032 battery
    -clean key fob contacts
    -tried different key fob altogether
    -reprogrammed key fob(s)
    Just to make extra sure it wasn't my fobs, I took them to both an Advance auto and a GM dealership and used their RF detectors to show that the unlock and lock buttons DO, in fact, reliably generate the correct signal every time they are pressed. Additionally, they are the two buttons used during programming, which also succeeds 100% of the time.
    I'm confused! Seems it's not the fob, or the receiver (because programming and the trunk work reliably). Intermittent body computer issue?
    Please advise. Thank you!
    Komrad36
    1998 Grand Prix GTP. Open cone intake, ZZP downpipe, dogbone flip.
  2. #2 Re: Bizarre issue with key fob (Tried ALL obvious fixes)
    Oct 2012
    Lithonia
    Your keyless entry receiver is probably going. That happened to my GP about a year ago. It started happening occasionally and then eventually everything stopped working. Now my trunks and locks work once in a blue moon.
  1. Wheel Bearing Issue or Tire Issue
    By ibra0078 in forum Tires & Wheels
    Last Post: 06-07-2013, 05:12 AM
  2. Overheating Issues, No Obvious Leak 04 GTP
    By wizsap in forum General Tech Discussion
    Last Post: 10-08-2012, 02:35 PM
  3. p0717, p0716, What fixes this
    By Jambat1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-08-2010, 10:57 AM
  4. Newbie fixes stalling with your help!!!
    By Gunfighter in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2009, 02:38 PM
  5. Common oil leaks and fixes?
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2008, 07:56 PM
