Hey guys I have a 2004 Pontiac Grand Prix GTP with 75,000 miles. The other day when I tried to start the car I got no response, no engine turning over at all so I assumed the battery was dead. Also I noticed the wiper blades were pointing up which I found odd since I had not used them the night before. The first thing I tried was to jump the car which did not work. So I got the battery tested at Autozone and I was told it was dead. I replaced the battery with a brand new one and the car still will not start. When I turn the key you can hear the fuel pump engage but no engine turning over. The keyless entry will not work, the power windows and locks do not work, and none of the lights inside the car and the radio dosn't work either. But you can hear a faint static coming out of the speakers even when the key is not in the ignition. However the headlights do work. So the battery is working and was part of the problem.. But now I am unsure what the actual problem is.. Possibly an electrical problem or my ignition swictch? Has anyone else encountered a similar problem? I have disconnected the battery so it does not get drained while the car is sitting. Any help or advice would be greatly appreciated. Thanks!
