Thread: Dyno charts and near motor destruction!
Results 1 to 11 of 11
  1. #1 Dyno charts and near motor destruction!
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Just finished putting my intercooler and 3.0 pulley on when my buddy decides to tell me that there is a mobile dyno 30min away.... had not even begun tuning..... well curiosity got the best of me and we went anyways... did the pulls in open loop (because pcm was trying to trim -10%!!!) and im pretty sure the hptuners scan said I was pulling mid 12s for fuel but it sure as hell was fun.... will probably make even better power tuned
    Motor has neverf had the heads or oil pan off with 165,000k on the clock.... it survived
    EDIT: Vidyas
    http://youtu.be/r16j1S28kG0
    http://youtu.be/ejqTjCG7co4
    Mods...
    L36 bottom end and heads
    zzp ssm90 LIM and Rails
    E85 ethanol sillyness
    GenV blower
    North* Throttlebody
    Ls2 maf sensor
    ER Rockers
    Speed Daddy headers
    60lb siemens injectors
    Casper fuel pump rewire
    180 tstat
    ZZP 1" intercooler core
    Bosch intercooler pump
    Wbodystore front mount heat exchanger
    K&N air box and filter
    AEM wideband and hptuners for tuning
    3.0 PULLEY
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  2. #2 Re: Dyno charts and near motor destruction!
    Florida
    My phones being gee aye why,but am i seeing 293whp and about 280wtq? If so not bad numbers.for those mods.
  3. #3 Re: Dyno charts and near motor destruction!
    Apr 2011
    South Dakota
    298whp was max.... we didnt start the run at a low enough rpm to get true torque but it still hit 287wtq
    I love Decker<3
  4. #4 Re: Dyno charts and near motor destruction!
    Was going to question the tq numbers then looked at the mod list again basically a gen5 e85 ic'd rocker car. Nice numbers for a pretty simple combo! More tuning and I'm sure you'll crack 300 in both hp and tq.
  5. #5 Re: Dyno charts and near motor destruction!
    Apr 2011
    South Dakota
    Spent this morning doing tuning. Got all of the narrowband trims near 0 again. Just gotta do Wide Fluffing Open stuff now. Might go back and see if they would let me run again without paying another 65$
    I love Decker<3
  6. #6 Re: Dyno charts and near motor destruction!
    65 for dyno runs that's cheap hell I wish I had a damn dyno near me at home!
  7. #7 Re: Dyno charts and near motor destruction!
    Florida
    Hell ive seen rockered cars making over 330 wtq with similar mods but a pull starting from a certain rpm makes a difference.
  8. #8 Re: Dyno charts and near motor destruction!
    Apr 2011
    South Dakota
    Helps if you arent running 13:1 for afr!
    I love Decker<3
  9. #9 Re: Dyno charts and near motor destruction!
    Max Cook
    Guest
    I love the bag of ice lol. I've always considered doing that at the track between runs but I figured it would just immediatelly melt the bag and get sticky plastic and water everywhere...
  10. #10 Re: Dyno charts and near motor destruction!
    Apr 2011
    South Dakota
    It sat on it for 45 mins with the car idling while they guy tried to figure out a good tach input and then went through 3 pulls and still had a decent amount of slush afterwards. The key is to make sure theres no holes in the bag so it stays filled with water.... if the water leaks out I imagion the plastic could melt. Mine probably lasts so long because my coolant ports in the blower are blocked and the intercooler does a wonderful job of not only cooling the air but also keeping my blower 50+ degrees cooler. My laser temp thingy said my blower was 95* so thats pretty awesome.
    I love Decker<3
  11. #11 Re: Dyno charts and near motor destruction!
    You need to come over here and tune my car lol.
  1. e85 Dyno Tune at Dyno Tune Motorsports - Video
    By tms8582 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2013, 07:57 AM
  2. Blower fan wont turn off with motor running , stops with motor off
    By bosull in forum Introductions/Noob Questions
    Last Post: 04-20-2012, 07:32 PM
  3. What's Next! Dyno or Not!
    By foursixer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2011, 02:11 AM
  4. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
  5. Dyno #'s
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 02-28-2009, 03:56 AM
