Thread: Battery Terminals
Results 1 to 4 of 4
  1. #1 Battery Terminals
    May 2012
    Canada , Sarnia
    I have an 04 gp and the battery terminals are broke it happened when i was installing the relay harness for my 55w HIDS the screws were old and rusty and broke now i have the terminals rigged up but now there getting to the point of making the car not start my parents went out and got me thishttp://www.canadiantire.ca/AST/brows....jsp?locale=en but i was looking at these Top Post Battery Terminal, Brass | Canadian Tire which one is correct and how would you install these???
  2. #2 Re: Battery Terminals
    that kind you cut off the old terminal, then strip back the insulation on the wire then clamp it on the new terminal. easy enough.
    only problem with that style is it leave the wire bare and exposed to air, then it will tarnish like copper does, its called dry wire. it will then travel down the wire and kill it slowly over time.
    or buy one that you solder on, or just buy a new cable altogether.
    heres how to solder one on, its easy.
  3. #3 Re: Battery Terminals
    May 2012
    Canada , Sarnia
    do you know roughly what a new cable cost
  4. #4 Re: Battery Terminals
    10 to 15 bucks most of the time, 20 tops.
  1. Battery
    By Lishap in forum General Grand Prix Discussion
    Last Post: 03-17-2012, 12:11 AM
  2. Amp to Battery
    By SE2001 in forum Audio, Security & Visual Electronics
    Last Post: 02-11-2012, 02:33 PM
  3. Battery
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2009, 11:21 AM
  4. battery help!
    By DDPeppa in forum General Tech Discussion
    Last Post: 08-23-2009, 11:49 PM
  5. Diagnosing corrosion on coil pack terminals
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-30-2008, 01:52 PM
