Thread: HUD?
Results 1 to 4 of 4
  1. #1 HUD?
    Oct 2008
    windsor
    Anyone know how to add HUD to a 2003 gt? What i need to know is are the wires there? Do i have to cut any part of the dash? And i have found a HUD that looks like it just fits right in. Is that true? How hard of a job would this be?
  2. #2 Re: HUD?
    I live here. UR LOSN's Avatar
    Rockford, IL
    You would either have to cut the dash to fit the HUD cover, or you would just need to buy a dash out of a parted out GTP.
    I am not sure if all harness' are the same with all the connectors.... it is possible you have the connectors for it in the dash already..... but if not I would pick up a dash harness out of a GTP as well.
    then this should just be plug and play.....
    hope that helps.......
  3. #3 Re: HUD?
    Oct 2008
    windsor
    Quote Originally Posted by UR LOSN View Post
    I found one on ebay from Morads, i would put up the address if i knew how. But it seems to have the dash part. i don't know.
  4. #4 Re: HUD?
    Rockford, IL
    if you can, just copy and past the URL. on the top of your brower it should have this web address when you find that auction. copy that address and just paste it in a reply.
hud
