Thread: Wrapping Crossover
Results 1 to 12 of 12
  1. #1 Wrapping Crossover
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    Is there a benefit of heat wrapping the crossover pipe? Will it crack? Also do you think it would be fairly easy to do without taking it off the car? Gracias
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: Wrapping Crossover
    I did mine on the car been that way for 2 1/2 years
  3. #3 Re: Wrapping Crossover
    Not worth it to me.
  4. #4 Re: Wrapping Crossover
    SWPA
    No benefit to be had.
  5. #5 Re: Wrapping Crossover
    Pennsylvania
    Benefit? No, it won't make the car faster, more reliable, or cheaper.
    Crack? It may be somewhat more likely but I doubt you'd see an issue on the stock crossover.
  6. #6 Re: Wrapping Crossover
    Arizona
    If you want to try and keep radiant heat from the crossover throttle body area than yea go for it. It won't hurt anything. I personally think it helps a little for keeping that tb from getting so damn hot. It can be done on the car. I've done it in my gtp and Gxp.
  7. #7 Re: Wrapping Crossover
    Jun 2013
    Hollywood ,FL
    that damn header gets so damn hot
  8. #8 Re: Wrapping Crossover
    Quote Originally Posted by kurupt305 View Post
    So does any exhaust system.
    Prolly 300-400ยบ.
  9. #9 Re: Wrapping Crossover
    Apr 2013
    Milwaukee
    Ok, I guess its either or then. I may try it if I have some extra time.
  10. #10 Re: Wrapping Crossover
    Omaha, NE
    Heat rises. In order to benefit from any kind of wrap, everything exhaust related under the hood would have to be wrapped.
    If you want cooler exhaust temps, get headers. Larger diameter, thinner walled piping allows for better cooling over stock manifolds.
  11. #11 Re: Wrapping Crossover
    You will add a pound or two of weight to the car. That's the only benefit I see.
  12. #12 Re: Wrapping Crossover
    I live here. DirtDog's Avatar
    Jun 2012
    What u add in weight by wrapping it u 97-03 guys will loose that weight in rust
  1. Interior Wrapping ???
    By Beelzeboul in forum General Tech Discussion
    Last Post: 09-23-2012, 11:04 PM
  2. wrapping headers
    By GOINDEF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2011, 08:51 PM
  3. Crossover and DP
    By minichopper6hp in forum Turbo
    Last Post: 02-26-2010, 04:13 PM
  4. Wrapping the crossover?
    By the1euge in forum General Tech Discussion
    Last Post: 04-20-2008, 07:04 PM
