Thread: Vs cam vs 1.9 rockers
Results 1 to 12 of 12
  1. #1 Vs cam vs 1.9 rockers
    SE Level Member Juskenny7's Avatar
    Oct 2012
    Hyattsville
    Which is better performance wise and which would you do?
  2. #2 Re: Vs cam vs 1.9 rockers
    So wrong section but I'm sure a mod will move it.
    Vs cam > rockers
    Had rockers originally. Took them out and sold them and bought a vs cam. Even though its not a huge cam it was still a good improvement over the rockers.
    04 Comp G.
  3. #3 Re: Vs cam vs 1.9 rockers
    Oct 2012
    Hyattsville
    Oh ok thanks... My bad about the section new to this
  4. #4 Re: Vs cam vs 1.9 rockers
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Cam gives more power throughout the entire power band but is more involved to install and tune. I pulled my motor last winter with plans to install rockers but decided to go with a cam instead. I'm glad I went to a cam now that the project is done but looking back had I just installed rockers I'd have a lot more money in the bank and just a little less get up and go lol
  5. #5 Re: Vs cam vs 1.9 rockers
    May 2012
    Where winter never ends
    Cam, but go XP. I was thinking VS decided the XP and would never go back. Oh and reallllly wrong section lol.
    2000 Regal - Winter Beater
  6. #6 Re: Vs cam vs 1.9 rockers
    Comparing rockers to a cam is like comparing smirnoff girly drinks to hard liquor.
    Sure...you can drink both...
    But one makes you a woman.
  7. #7 Re: Vs cam vs 1.9 rockers
    I had modded 1.9's on my 98 and went with a s1x on my comp g. I'm liking the cam a lot more.
  8. #8 Re: Vs cam vs 1.9 rockers
    Oct 2012
    Hyattsville
    With the Xp cam what all do you have to modify to support the cam
  9. #9 Re: Vs cam vs 1.9 rockers
    Nothing more than if you did the vs cam
  10. #10 Re: Vs cam vs 1.9 rockers
    Oct 2012
    Hyattsville
    I'm asking if I put the cam in what would I need to support it
  11. #11 Re: Vs cam vs 1.9 rockers
    Should change the timing chain and damper springs and retainers
  12. #12 Re: Vs cam vs 1.9 rockers
    May 2008
    Schuyler, NE
    That is incorrect.
    With the XP cam, you need milled retainers, and you should install shorter valve seals as well. The XP will also require heavier springs.
  1. cam vs rockers
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-24-2010, 08:46 AM
