Thread: Coolant temperature reading
Results 1 to 5 of 5
  1. #1 Coolant temperature reading
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    What should the reading look like with a 180* Tstat? Right now mine reads right in between the 160 and 210* mark.
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: Coolant temperature reading
    That's right in the area. Because.. 180 is right in between 160 and 210.
  3. #3 Re: Coolant temperature reading
    Apr 2013
    Milwaukee
    Ok, I must of had a 180* when I bought the car then. Where would the 195* read?
  4. #4 Re: Coolant temperature reading
    GTP Level Member tms8582's Avatar
    Washington Michigan
    With stock PCM settings the motor will get hotter sitting still because the fans don't turn on until like 220 (unless the air is on then the low speed fans come on) Even with the 180 stat mine ran hot sitting still until I changed the settings. Now I have them set to have low speed fans come on at 180 and high speed at 190 or something close to that. This keeps the needle about 185 all the time in summer. You would have thought that all cars equipped with the L67 would have had these setting from the factory considering the supercharged motor???
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  5. #5 Re: Coolant temperature reading
    Apr 2013
    Milwaukee
    Ya, on my tune I have the fans kick on around 180-185 I believe and it keeps it right in the sweet spot. Rarely does it go past the middle mark except in stop and go traffic. Before my tune, it would go as far as 220 or so. One great reason to get a tune.
  1. External temperature reading is way low - A/C blows hot air
    By alecswan in forum General Grand Prix Discussion
    Last Post: 10-09-2017, 02:04 PM
  2. Replacing coolant temperature sensor
    By vertebrate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2013, 01:43 AM
  3. Temperature gauge reading hot!
    By gloryabides in forum General Grand Prix Discussion
    Last Post: 01-10-2013, 10:31 PM
  4. New Coolant sensor now reading wrong temp
    By jhnnyboz in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-18-2011, 08:57 PM
  5. Exterior Temperature reading wrong
    By 2000GrandPrixGT2000 in forum General Tech Discussion
    Last Post: 09-07-2010, 04:49 PM
