Hi y'all...where can u buy the shift solenoid?
Under the steering column...its a little white piece...just rip it out and be done and don't replace it.
The one that stops you from shifting is on teh passengerside of the shifter assembly. Right under the button that says "Shift Interlock"
where can I get a new shift solenoid?...I dont want to replace the whole shifter mechanism...It's $300 from g.m.
It's a $30 part from a junkyard. Probably cheaper than just the piece. I'd see waht you need to do to put a soleniod on. I'm not sure it's a swappable part.
