Thread: how to replace the snout on a gen 3 m90
Results 1 to 11 of 11
  1. #1 how to replace the snout on a gen 3 m90
    Jul 2013
    adrian, mi
    I'm askng ths question because I have 3.4 mps already pressed on a snout and want to just replace it all as one.
  2. #2 Re: how to replace the snout on a gen 3 m90
    It's rather simple...use a syringe and drain the supercharger oil and then remove the 9 bolts that hold the snout and case together.
    04 Comp G.
  3. #3 Re: how to replace the snout on a gen 3 m90
    Jul 2013
    adrian, mi
    I fugured that much didn't know to expect if there's a gasket on the snout can't find anything like that at the local auto parts store not sure what to expect inside
  4. #4 Re: how to replace the snout on a gen 3 m90
    You'll want some anerobic sealer for when you put the snout back on.
    Because there is no gasket, the sealer is used.
  5. #5 Re: how to replace the snout on a gen 3 m90
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    Like said above its pretty simple to do. Make sure you have rags under the snout to catch any excess oil that doesn't come out with the syringe.
    If it's an MPS. buying a 3.8 would be cheaper generally unless you already have the new snout
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  6. #6 Re: how to replace the snout on a gen 3 m90
    Wear gloves do not get the old SC lol on your hands or you will hate yourself for the week and do it outside if its possible. The smells bad you don't want that inside.
    04 Comp G.
  7. #7 Re: how to replace the snout on a gen 3 m90
    Smell isn't that bad. Be a man!
  8. #8 Re: how to replace the snout on a gen 3 m90
    Jul 2013
    adrian, mi
    Yeah already have the snout with the pulley on it. Thanks guys
  9. #9 Re: how to replace the snout on a gen 3 m90
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    be careful not to jerk the rotor pack out!!!
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  10. #10 Re: how to replace the snout on a gen 3 m90
    Quote Originally Posted by dbextreme View Post
    Why?
    Its not like it matters if it comes out or not.
  11. #11 Re: how to replace the snout on a gen 3 m90
    Nov 2009
    Tennessee
    I haven't had good luck with needle bearings, so better safe then sorry...
  1. Pig Snout
    By TheNoob23 in forum Off Topic Discussion
    Last Post: 11-28-2012, 03:24 PM
  2. Replace supercharger or the snout &coupler?
    By sav24dl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2011, 01:05 PM
  3. YT Snout
    By Ibwrong in forum General Tech Discussion
    Last Post: 05-06-2010, 12:48 PM
