Thread: ported manifolds
Results 1 to 9 of 9
  1. #1 ported manifolds
    Jul 2013
    adrian, mi
    i plan on getting headers in the future but right now i have a set of ported manifolds. will they give anything noticable in terms of reducing kr. i have a 3" dp, 104's, fwi, 180*tstat and always 93 at the pump. i wanna put a 3.4 mps on this wkend so hopfuly my scanner comes in.
  2. #2 Re: ported manifolds
  3. #3 Re: ported manifolds
    In my experience the biggest restriction on the stock manifolds is the front manifold where it bends and restricts. You can't port it in that area and therefore.. a set of ported manis don't fix the issue.
    Personally having done ported Em's in the past. I wouldn't do it again. I'd go straight to plog or headers.
  4. #4 Re: ported manifolds
    i don't like the log style manifolds, even if they are better than stock.
    how it is that hard to reproduce the stock bends and shape, with better diameter piping?
  5. #5 Re: ported manifolds
    Texas
    Because its the stock bends that make it flow poorly.
    85 Corvette
    01 TA
    03 Z06
  6. #6 Re: ported manifolds
    they're tubular, how can the bends be bad?
    make a plog...but make the bends pretty, kinda like how stock LOOKS.
  7. #7 Re: ported manifolds
    Apr 2012
    Goderich, Ontario
    I got a ported front manifold sitting in my garage that I got for free. Was wanting to put it on soon and hope I don't brake any studs. However, after reading this I might not bother, if it doesn't really do anything.
    -Paul Walker
  8. #8 Re: ported manifolds
    Jul 2013
    adrian, mi
    Mine were Both free kinda bummed the general consensus is nothing. Well it can't hurt it. I will just try it with the stock ones scan and make a pass at the local strip see what's going and then try the ported ones and repeat.
  9. #9 Re: ported manifolds
    The obstructions in the manifold are in the primaries where they join...not the inlet that touches the cylinder head.
    You can't really port that without cutting up the manifold and rewelding everything.
    Would it hurt?
    No.
    Is it worth it?
    Probably not.
    I had a wrapped x-over...and I ported my front/rear manifolds at the same time I did a 3" DP.
    I noticed a difference but it was probably all in the downpipe.
  1. Power Log vs Ported Manifolds
    By carcrobatics in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-05-2013, 08:24 AM
  2. XP cam and topswap on Ported manifolds?
    By BlackGT97 in forum General Tech Discussion
    Last Post: 02-22-2013, 01:55 PM
  3. Ported manifolds
    By Fcukit33 in forum Engine
    Last Post: 09-27-2010, 10:23 PM
  4. Ported exaust manifolds
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2008, 02:39 PM
