Thread: cant shift out of park
Results 1 to 5 of 5
  1. #1 cant shift out of park
    May 2013
    ca
    Hi y'all...where can u buy the shift solenoid?
  2. #2 Re: cant shift out of park
    Under the steering column...its a little white piece...just rip it out and be done and don't replace it.
  3. #3 Re: cant shift out of park
    The one that stops you from shifting is on teh passengerside of the shifter assembly. Right under the button that says "Shift Interlock"
  4. #4 Re: cant shift out of park
    May 2013
    ca
    where can I get a new shift solenoid?...I dont want to replace the whole shifter mechanism...It's $300 from g.m.
  5. #5 Re: cant shift out of park
    It's a $30 part from a junkyard. Probably cheaper than just the piece. I'd see waht you need to do to put a soleniod on. I'm not sure it's a swappable part.
  1. Key stuck in ignition, won't start, won't shift out of first park !!.
    By microterf in forum Audio, Security & Visual Electronics
    Last Post: 09-29-2012, 08:44 AM
  2. Key stuck and car won't shift out of park
    By chrisLB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-01-2012, 11:47 PM
  3. Can't remove key or shift from park
    By airhead in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2012, 07:58 PM
  4. my car wont shift from park without pressing relese button
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-12-2012, 12:49 AM
  5. Won't Shift Out of Park (sometimes)... Ignition Switch?
    By GTFiske in forum General Tech Discussion
    Last Post: 01-12-2011, 12:53 PM
