Thread: Power Door Locks
Results 1 to 3 of 3
  1. #1 Power Door Locks
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    The power lock button on both doors only lock / unlock the drivers door.. All other doors must be manually controlled. Does anyone know the possible cause?
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  2. #2 Re: Power Door Locks
    will the key fob lock and unlock them all? does the pass side door lock switch work?
  3. #3 Re: Power Door Locks
    Jan 2009
    ny
    No, the fob will not lock the doors and yes the passenger side power button works. The power buttons will only lock n unlock the drivers door.
  1. Power Door Locks
    By tdm571 in forum Audio, Security & Visual Electronics
    Last Post: 05-06-2013, 09:09 AM
  2. no crank, no power, key locks, shifter locks
    By flames1819 in forum PCM Tuning
    Last Post: 01-07-2012, 06:06 PM
  3. Door locks
    By shawnschuldt in forum General Tech Discussion
    Last Post: 04-26-2011, 02:58 PM
  4. door locks/BCM/speaker/ door question
    By adamlesandrini in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2009, 05:14 PM
  5. Power Door Locks not working
    By webracin in forum General Tech Discussion
    Last Post: 12-27-2007, 10:57 AM
