Thread: Ok...searched high and low with no results, so here it is:
Results 1 to 8 of 8
  1. #1 Ok...searched high and low with no results, so here it is:
    Jan 2013
    North Carolina
    Define irony: I have a SEL on, but can't figure out what the error code is because apparently my OBD-II connector has no power! Anyone? Anyone? Beuller? Beuller?
  2. #2 Re: Ok...searched high and low with no results, so here it is:
    check your lighter fuse, the obd2 port is powered off the same fuse.
  3. #3 Re: Ok...searched high and low with no results, so here it is:
    GT Level Member Knightmare's Avatar
    Jul 2011
    Frederica, DE
    I have a similar issue going on...but I checked my fuses and even replaced it just to be sure and still nada....scanner says "communication line terminated due to over current protection"...car runs fine...but the light bothers me....happened around the same time that my airbag light came on lol
    Hope yours is a simple fix my friend :-)
    Sent from my SGH-I777 using Tapatalk 2
  4. #4 Re: Ok...searched high and low with no results, so here it is:
    Jan 2013
    North Carolina
    Lighter works fine, power outlet works fine; just no juice to the OBD-II connector. I'll recheck my fuses, but if the lighter's working, I don't see how it could be blown. Thanks for the input, guys! Anyone else?
  5. #5 Re: Ok...searched high and low with no results, so here it is:
    check the wires on the back of the obd port, (wires break off sometimes) also make sure the inside of the plug is clean, no dirt or lint inside it or anything that could keep it from connecting.
  6. #6 Re: Ok...searched high and low with no results, so here it is:
    Jan 2013
    North Carolina
    Ok, thanks for that...next on my list! I'll let you know what comes of it!
  7. #7 Re: Ok...searched high and low with no results, so here it is:
    Max Cook
    Guest
    Mine did this once. Turned out my PCM was messed up. It worked fine with everything else except reading and writing to it. Had to replace it.
  8. #8 Re: Ok...searched high and low with no results, so here it is:
    Jan 2013
    North Carolina
    I really hope that's not my issue, Max!! But I will keep it in mind.
  1. CAI-Already searched the forums
    By Bkindhart in forum 04+ Specifics
    Last Post: 04-24-2013, 09:13 PM
  2. 3.29 Question, and i searched a LOT
    By steves86ta in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-12-2012, 12:45 PM
  3. HEADER Q''S (searched for but no luck)
    By speed demon in forum General Tech Discussion
    Last Post: 06-14-2012, 12:28 PM
  4. Cooling fans, stumped. yes I searched
    By smallheadz in forum General Tech Discussion
    Last Post: 03-20-2012, 08:16 PM
  5. A/C Troubles, I'm all searched out.
    By JESSEGOTTA GP GT in forum General Tech Discussion
    Last Post: 04-17-2010, 04:58 PM
