Thread: Camshaft bearing replacement a must?
Results 1 to 2 of 2
  1. #1 Camshaft bearing replacement a must?
    May 2012
    Albuquerque, NM
    Hey guys, decided to go with a cam instead of rockers on my top swap. I've read I "need" to replace my camshaft bearings but I rarely hear anyone say they do it. Is it a must, a recommended item, a good thing, or a if you can why not?
    TIA,
    Slim
  2. #2 Re: Camshaft bearing replacement a must?
    if your pulling the engine out i'd change them. its not that hard to do.
    once your cam is out if not pulling the engine you can look at them, if you see copper metal showing, they are worn out and should be changed. still shinny metal, they should be ok to re use.
  1. 2005 GP Hub Bearing Replacement
    By Chainsaw6966 in forum Brakes/Suspension/Chassis
    Last Post: 06-25-2013, 02:07 PM
  2. wheel bearing replacement?
    By loganrick in forum Brakes/Suspension/Chassis
    Last Post: 01-10-2012, 12:28 AM
  3. camshaft bearing replacement ? how to ?
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2011, 11:24 PM
  4. snout bearing replacement
    By RICE KILLER in forum How To Write-Ups/Tech Tips
    Last Post: 08-13-2011, 09:47 AM
  5. Supercharger Bearing Replacement!!
    By Motter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2010, 11:23 AM
