Thread: electric issue - all power loss, gauges twitching when turned to run position
Results 1 to 8 of 8
  1. #1 electric issue - all power loss, gauges twitching when turned to run position
    GT Level Member hacket's Avatar
    USA
    Backed out of the driveway, put it in D and the car flatlined as though the battery had been disconnected. Got out and checked the connection to the battery and it was fine. I left the key in the 'run' position and within 5 seconds, it had power again. Did it again about 30 seconds later. Then all worked fine and got to work alright.
    At work I played with it a bit and got it to do it again, while NOT running. Turning it to 'run' a couple times, it lost all power and the gas gauge and odometer started twitching up and down.....just like when you turn it to 'run' the first time. Know what I'm talking about?
    Any intuition would be awesome. 1998 Grand Prix SE 3800 with 196K.
    http://faceyourfinances.blogspot.com/
    1998 Grand Prix SE 3800 Engine, Metallic Green, Gold Rims with stock spoiler, Bought with 112K in May 05; Currently : 182K
  2. #2 Re: electric issue - all power loss, gauges twitching when turned to run position
    Possible ignition switch
    Test for power coming out of the switch when it's not working.
  3. #3 Re: electric issue - all power loss, gauges twitching when turned to run position
    USA
    There is no power to anything, even the radio. The clock got reset to 12:00 every time it happened.
  4. #4 Re: electric issue - all power loss, gauges twitching when turned to run position
    I believe that leads to a battery connection issue based on clock. I don't think battery power for it runs through the ignition switch.
  5. #5 Re: electric issue - all power loss, gauges twitching when turned to run position
    USA
    I am not too electrical savy......could a short anywhere in the electrical system cause it to lose all power to the point of resetting the radio?
  6. #6 Re: electric issue - all power loss, gauges twitching when turned to run position
    USA
    thought i'd let anyone else viewing this that it turned out to be a bad connection coming off the body back to the battery. Very corroded and dirty. Cleaned it up and everything has been perfect for over a month
  7. #7 Re: electric issue - all power loss, gauges twitching when turned to run position
    SE Level Member YZ250rider's Avatar
    Aug 2012
    Sioux Falls, SD
    I'm having kind of the same problem. I will shut off my car and my battery dies. Sometimes it turns on right away, sometimes it doesn't. I don't know what's going on. I figured there had to be a short somewhere. Anyone know?
  8. #8 Re: electric issue - all power loss, gauges twitching when turned to run position
    USA
    Are you losing ALL power, as in even the radio and trunk lights?
  1. Power Loss
    By Stinkygrub in forum Engine
    Last Post: 07-20-2021, 09:11 PM
  2. Need Help! Loss of Power
    By 01GTLAK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2012, 03:41 PM
  3. Loss of gauges
    By jmoore4294 in forum 04+ Specifics
    Last Post: 04-04-2011, 04:51 PM
  4. power loss when hot
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-30-2009, 03:23 PM
  5. loss of power to gauges
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2009, 12:58 PM
