Thread: Rough Idle after Rainstorm
Results 1 to 6 of 6
  1. #1 Rough Idle after Rainstorm
    May 2013
    South Dakota
    Not sure I'm in the right place, but I hope someone can give me some advice! I have a 1993 Pontiac Grand Prix SE, with the 3.1. Up until a few days ago, it was running fine. This weekend we had a really bad rainstorm, and some of the roads flooded. I had to drive through an area that was "flooded," there was about 6 inches of water on the road. I was going a little fast when I hit the water, so it splashed up, and then the car sputtered and died. I pushed it until it was out of the water, let it sit for about 15 minutes to dry out, and then started it. It seemed to be running fine, and I got home okay. I then left my dome light on, and killed my battery. This was about three days ago, and we had another round of rain during that time.
    Today I charged up the battery, started it up, and it's idling very poorly. The best was I can describe it is that it sounds like a drag car at idle, super rough. I check the air cleaner and it was still damp, and looked in rough shape, so I replaced it. It seemed a little better, but it's still not right. If I drive it, it runs fine, but idles pretty fast, if thats the right word for it. It seems to stay close to whatever speed I accel to. If I bring it up to 40, and then take my foot off the gas, it'll stay at forty, I have to brake to bring it down. The slowest I can keep it at is around ten, any lower and I have to hold the brakes. When stopping, I get just about to 0, fighting the engine, and then it "slams" down into the rough idle again and stops, but doesn't die (not yet anyway). A few times the check engine light has come on while stopped, and then goes off after a bit.
    Any ideas on what could be wrong?
    1993 Grand Prix SE 3.1
  2. #2 Re: Rough Idle after Rainstorm
    could be your plug wires are shot, and the water finished them off, not sure if you have coils on a 93 but one could be cracked and got wet and shorted out. or if you have a cap and rotor they could need changing as well. water makes the rotor corrode.
  3. #3 Re: Rough Idle after Rainstorm
    May 2013
    South Dakota
    If it was an ignition problem would it still run fine above idle? I'll take a look at the wires as soon as I can. Also, as an update, I've noticed that if I throw it in neutral while moving, and then slow to a stop, the RPM stays pretty high until I stop, and then it drops down to the rough idle.
  4. #4 Re: Rough Idle after Rainstorm
    May 2013
    South Dakota
    After some research, I found out how to jump the OBD1 connector so that it would flash out the codes, and I got a code 33. From what I found this is a MAP sensor error, that the signal is high, possibly indicating low vacuum or a bad sensor. Would this cause the problems I am experiencing? The check engine light only came on a few times, when I had stopped after driving, and the engine returned to the rough idle.
  5. #5 Re: Rough Idle after Rainstorm
    a vac leak could make it idle rough, i guess if you find no leaks, ( spray some carb cleaner around the vac lines, if the idle jumps you found the leak area) then change the map sensor.
  6. #6 Re: Rough Idle after Rainstorm
    May 2013
    South Dakota
    Sorry I don't mean to bump an old thread, I just wanted to post what ended up being wrong. I took it in to a local shop and they found that the idle control motor was stuck too high, so they replaced it and now it's running fine.
  1. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  2. Rough idle
    By 7point62 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-21-2012, 01:28 PM
  3. rough idle
    By stanggreg90 in forum General Tech Discussion
    Last Post: 05-22-2010, 11:37 PM
  4. GTP Rough Idle
    By jaredhagen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2010, 01:32 PM
  5. Rough Idle
    By hacket in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-29-2009, 02:39 PM
