Thread: Water in trunk
Results 1 to 7 of 7
  1. #1 Water in trunk
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    I have water in my trunk, not inside on the carpet, but actually in the trunk door. When I open it, I hear a bunch of water splashing around. I filled my washer fluid before I realized my pump is shot and I don't know if that would cause this issue since there's no rear wiper, but I thought I would mention it. Since the water got in there, there's got to be a way to drain it out.
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: Water in trunk
    Sorry but what do you mean you filled your washer pump?
    04 Comp G.
  3. #3 Re: Water in trunk
    Quote Originally Posted by K Kraziee View Post
    I have a lot of water in my trunk, like the actual door part. I don't know how it got in there and I'm trying to figure out if there's anyway to drain it out. My washer pump isn't working and before I found that out I filled it out and about a week later there wasn't any fluid in the reservoir but I don't think it's from that. I don't know, please help me out guys.
    retype this, and clear it up. not sure where you got water.
  4. #4 Re: Water in trunk
    Agreed. As of right now I'm confused as s**t what your actual problem is. Calm down take a few minutes and please retype your problem.
    04 Comp G.
  5. #5 Re: Water in trunk
    What door on the trunk?
  6. #6 Re: Water in trunk
    Apr 2013
    Milwaukee
    Edited. Like the actually lid of the trunk, you know, where the spoiler sits on. Actually inside that part.
  7. #7 Re: Water in trunk
    Apr 2009
    Maine
    LOL wiper fluid in the trunk...
    Most likely some water has leaked in below the spoiler. The spoiler is held on with some nuts and double sided tape. Take the nuts off (I think there's 4), then you may have to pry up on it to get the double sided tape to release. Mine was some sort of foam/tape, so it came off pretty easy. Get all the tape off and clean it up as best you can. Then when you put it back on, use some rubber washers to raise the spoiler up a couple millimeters at the bolt holes. Instead of taping it back down, you let water pass under it. Finally after tightening down the nuts, apply some silicone around them to prevent any water from leaking into the trunk.
  1. Water in trunk
    By gpgt98 in forum General Tech Discussion
    Last Post: 03-06-2015, 09:14 PM
  2. Bad water pump,wrong water pump? 2002 GTP
    By R STARR in forum Introductions/Noob Questions
    Last Post: 06-03-2013, 06:47 AM
  3. Do you run distilled water or water out of the tap in your cars?
    By Slick2500 in forum Off Topic Discussion
    Last Post: 10-14-2012, 10:59 AM
  4. water in heater blower fan or water on passanger floor
    By coolcat2010 in forum How To Write-Ups/Tech Tips
    Last Post: 03-19-2010, 04:20 PM
  5. trunk water leak
    By abweiss in forum General Tech Discussion
    Last Post: 11-25-2009, 08:28 AM
