Thread: Vac readings n engine temps
Results 1 to 4 of 4
  1. #1 Vac readings n engine temps
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    So I just got my AC compressor replaced. I've been without ac for 2 years since I bought the car. I noticed my Vac readings on y boost gauge is around 17psi opposed to the normal 20psi it use to be at at idle or at a stop with the ac on. Also with the ac on, my car is running slightly hotter than normal. Prolly around the 200 or so mark, it's a couple notches higher than the stock temp notch on the gauge cluster with the ac on. Is this normal for having ac on? Vac readings were at a dead 20 psi idle and dead even between 210 and 160 for engine temps.
    1998 Grand Prix GTP Daytona - CAI, XP Cam, Iceman tune, Speed Daddy Headers, 3.2 in pulley, Ported blower, Al 103's, 3in Catless DP, Transgo "shift kit", No resonator to Magnaflow Mufflers. 93K Miles
  2. #2 Re: Vac readings n engine temps
    Nov 2011
    Indiana
    Just arrived at work, at its around 16-17 psi vacuum in drive at a standstill, buy 19-20
    vac in park
  3. #3 Re: Vac readings n engine temps
    Normal.
  4. #4 Re: Vac readings n engine temps
    Nov 2011
    Indiana
    K good thank you
  1. Map readings?
    By Zzp98gs in forum General Tech Discussion
    Last Post: 06-08-2013, 10:21 PM
  2. crazy high trans temps or no temps!? pics!
    By blknbstd in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-20-2011, 06:07 AM
  3. O2 readings
    By Silver GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2010, 10:44 PM
  4. O2 readings
    By Progas in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2008, 02:24 PM
  5. theorizing on rising engine temps
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-11-2008, 11:37 PM
