Thread: Car not running right. Help
Results 1 to 8 of 8
  1. #1 Car not running right. Help
    Connecticut
    So I've been having some problems with the gp. Rough idle, studdering, loss in power, running rich, sounds terrible like it's not running on all 6. SES flashing, Threw a P0300. Basically running like crap. When it first happened I cleared the code unplugged the battery for 15 min and it started up fine and went away. Then 15 min later it started again. So I changed the plugs and wires. Still doing it. Scan Guage told me it's cylinders 1 and 4 misfiring. So I changed the coil pack for 1 and 4. It went away then came back a day later. I swapped out coil pack 1 and 4 with 2 and 5 to see if the new coil pack was faulty and it was still misfiring in cylinders 1 and 4. I unplugged the MAF and it reads no misfires but still runs like crap so I also replaced the MAF but that didn't change anything. I heard the injectors don't go bad very often in these cars especially two at a time so that leaves me to believe it's the ICM. It's a 97 se 3.8 80,000 miles. Any ideas would be greatly appreciated. Thanks.
  2. #2 Re: Car not running right. Help
    Jun 2013
    Middleville
    use a long screwdriver and place it on the #1 injector and put you ear up to the screwdriver if you hear a clicking noise that increases with the engine speed then that injector is working. You can do it on a known working injector to know what sound your looking for. I would start with that and see what you find out. Then do the number four cylinder. If thers no clicking noise its a bad injector.
  3. #3 Re: Car not running right. Help
    Connecticut
    Thanks for the tip. I just tried it and all 6 are clicking perfectly and increase with engine speed. So I guess it's not the injectors
  4. #4 Re: Car not running right. Help
    Max Cook
    Guest
    When you pulled the plugs were any broken?
  5. #5 Re: Car not running right. Help
    Connecticut
    Nope the plugs were all in tact
  6. #6 Re: Car not running right. Help
    Jun 2013
    Middleville
    If it were me my next step would be to make sure they are spraying right. I would pull the rails out and turn the key over and watch all six with the engine cranking make sure its a fine mist pay extra attention to the one and four cylinder. Be careful and put pig mat down and dont smoke obviously but i would try that and see what the results are
  7. #7 Re: Car not running right. Help
    Connecticut
    I fixed it it was the ICM. Swapped out for a new one it's running better than ever. Thanks!
  8. #8 Re: Car not running right. Help
    Jun 2013
    Middleville
    cool easy fix
  1. l67 engine wont stay running..got the car running. tons of white smoke from exhast
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 05:14 PM
  2. 03 Top Swap running hot UP AND RUNNING
    By The Guz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2013, 02:19 PM
  3. Anyone running these?
    By h0wl0ngcanitbe in forum Visual/Body Modifications
    Last Post: 04-16-2012, 03:43 PM
  4. what a/f should i be running??
    By Wisconsingrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2012, 12:21 PM
  5. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
