Thread: Coolant leak
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: Coolant leak
    that looks like a O ring there, maybe you can just change it and pop it back in? looks easier then a freeze plug to get in or out.
    clean the freeze hole in the block up, use some high heat rtv or something around the O ring to help it seal up. re install it?
  2. #22 Re: Coolant leak
    yeah, a coolant flush and 3 cans of de greaser. your engines pretty damn dirty. looks like the valve cover gaskets need to be changed.
  3. #23 Re: Coolant leak
    GT Level Member fri3dchick3n's Avatar
    Alaska
    Honestly, I look at the O Ring and it looks good. I will try to see if I can atleast replace that part. I think the tightening system for this just might have loosened up a little bit.
    My oil pan is leaking a little bit, engine mount has asploded, and I think I do need new valve cover gaskets, atleast the rear one. Thats all on my summer list It will get done.
    They make canned de greaser? Spray and clean?
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180ยบ Thermostat, Flipped Dog Bones
  4. #24 Re: Coolant leak
    they sure do. gunk engine foamy bright, crc de greaser, < has very little smell after hosed off. then there the Green cleaners.
    dont clean it in your drive way, it will leave one hell of a mess when done under the car. do it in the street or over dirt.
    being as thick as it looks, you'll need to do it a few times, then use a stiff paint brush to break what wont come free on it own loose.
    i always get 2 cans, cause one can is never enough, but your looks like a 3 can job. stuff cheap here, about 5 a can, dont know what the mark up will be in the Alaska.
  1. Coolant Leak
    By Doogie8044 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-16-2012, 11:32 AM
  2. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  3. Coolant Leak, But Where??
    By brandonl2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2011, 10:46 PM
  4. coolant leak
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2011, 11:56 PM
  5. bad coolant leak
    By johnfolks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-08-2011, 04:30 PM
