Thread: Twin engine GTP project progress thread
Page 19 of 24 FirstFirst ... 91718192021 ... LastLast
Results 361 to 380 of 469
  1. #361 Re: Twin engine GTP project progress thread
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    You.... broke a 4t80e.. c'mon man.
  2. #362 Re: Twin engine GTP project progress thread
    hangover park IL
    Quote Originally Posted by SnowTh1ef View Post
    id reserve judgment on that. just from not changing the primary pump filter when he yanked it from the junkyard.
    its pretty well known that filter being a pita to replace is the leading cause of failure...most people dont wanna pay 9 hours of labor to change their trans filter. its laughable that gm says its "recommended" replacement is at 100k.
    howd that 100k maint interval dexcool workout? any of you ever leave your filter in yer trans for 100k?
    im gonna go out on a limb here and figure they knew it was an issue, and instead of that filter being replaced at a 30 or 60k interval, its in there for far too long getting clogged up, and more clogged it gets, the better of a filter it is, so it clogs up exponentially faster. but hey its a maintenance item, and the trans will easily last till out of warranty, even starving for fluid (gotta love trans adaptives that hide potential problems from the owner! yay!)
    i kept the TR's shattered trans going for a while after we shredded a tq converter by replacing the filter every 100 miles lol, every time id hear the cold start whine...
    to be fair the 80e's ive pulled have all had grit and **** in the pan, the fill cap has a habit of collecting crap around the lip and when you yank the dipstick a surprising amount of crap can fall in, oil change joints don give a fuuuuck...
    as for the external filter, it would help, i dont like the potential restriction on the trans cooler lines (doubt people would spend the $ for a bypass filter setup) but the simple fact is that when you buy a good used 80e for 150$, you spend 15$ for a new filter and install it, your good for 50k+
    the only things that are an issue are the solenoid failures, and known issues that sonnax has fixes for, which are in the valvebody in the lower pan, much easier to get to than the 65e...
    shoot though at least when you have the side cover off changing that filter... the 2-3 accum is staring at you, yank it out and shove some 5/16ths spacer nuts on the shaft.
    i wouldnt say he found the true weak point of the 80e....he just found the common failure due to lack of filter service.
    it'd be like saying the 3800 is weak as hell cause it blew up with leaking dissolved 100k+ mile LIM gaskets ****ting dex internally.
    i still think it'd be a swell idea to have the pcm control it so you can at least record trans data...im not saying' im just sayin....
    ~James~ Psychotic Gearhead
  3. #363 Re: Twin engine GTP project progress thread
    Arizona
    I'm using all half inch lines for my trans cooler and remote trans filter think that might help in this case?
  4. #364 Re: Twin engine GTP project progress thread
    GTP Level Member TwinV6GTP's Avatar
    May 2013
    Gatineau
    To me the way it popped out of gear suddenly, felt like it just could hold all the torque off the line. I'm making ridiculous torque on the rear engine now.
    Because of the small turbo that spool quickly once it reaches a certain PSI. It takes 3 seconds to build 10 psi but 1 more second it's 20psi, then when I launch it shoots to 28-30 psi almost instantly.
    That's when it popped into neutral. Then slammed back in gear after 2 seconds of free revving.
    Before this, the trans didn't slip at all, shifted well etc... There was no sign of impending failure. I know for a fact I'm pushing way more torque than that trans was made to handle.
    In my opinion the hard parts can take more, but the clutch packs can't.
    2015 Custom Twin Engine Nascar style car with dual GTP 3.8 drivetrain, Front trans 4T65e-HD, Rear 4t80e trans 1/4 mile 8.38 @ 165mph
    2000 GP Twin Engine Twin TD Turbo kits. Stock engines stock trans(s) stock injectors stock MAFs 0-60mph 1.8 seconds 1/4 mile 9.72 @ 139 mph
  5. #365 Re: Twin engine GTP project progress thread
    Feb 2009
    flintnasty MI
    Any boost passed 18ish psi isnt going to flow much more if any air at any rpm on your setup so dont expect to relate psi directly to torquE
  6. #366 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    Yes it does, especially at low RPM when you run a super tight torque converter.
    At 22 psi I make great power. From 22 psi to 30 psi, only small gains, mostly torque gains at low to mid RPM. High rpm = no gains.
    I get better ET but only slightly better MPH.
    25 psi is about the best boost for my set up on my turbos. Over that minimal gains are seen.
    Torque is definately very high my guess in the 500 ft-lbs+ at 30 psi
  7. #367 Re: Twin engine GTP project progress thread
    hangover park IL
    I'm just saying that your not exceeding peak torque capacity if you had a trans with a filter needing replacement.
  8. #368 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    Quote Originally Posted by Turbocharged400sbc View Post
    We have the trans apart. Filter blockage was not an issue. It is not perfectly clean but it was not nearly blocked either. Not enough crap there to block it.
    The typical 4t80e fixes by Sonnax. One of them check out ok (test explained by sonnax) Shaft leakage = no
    We have at least one broken band (low/reverse) clutch packs coming out. garanteed they are damaged.
  9. #369 Re: Twin engine GTP project progress thread
    SE Level Member SlowFiero's Avatar
    Feb 2008
    Canada
    I would take a really good look at the sprag assemblies. What you are describing sounds very similar to what my 65 did when I broke the input sprag. Sometimes it would grab and you could drive slowly, but once you put a load on it, it would fail again, and basically be in nuetral. The last one popped a few times, I could brake boost it a bit, but on launch it would release and the car would not move. Eventually it failed completely and I had no first gear.
    Billet 6262 T3 turbo, PT1001 intercooler, ST1 cam, 140 springs, pushrods, N* TB, L26 upper, HV3, otherwise stock L32. 10.007 @ 135.54with 1.46 60' 3130 lbs
    Old GenV M90, XP, heads, N* TB, ST2 intercooler - 11.425@115.60 1.54 60'
  10. #370 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    Same symptoms except i get my gear back by messing around driving shiftubg manually. I have most of the trans apart now. Broken low/reverse band and burnt forward clutches.
    Sent from my iPhone
  11. #371 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    Sent from my iPhone
  12. #372 Re: Twin engine GTP project progress thread
    Never Never Land
    Sweet
  13. #373 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    Even the 4t80e cant take the load. The one i have now has less miles and pan was mint. Nice used fluid as well.
    I will keep torque reasonable and run more boost once underway
    Sent from my iPhone
  14. #374 Re: Twin engine GTP project progress thread
    How sure are you that all that was only you and not previous owner. It was a JY unit without history for the most part.
  15. #375 Re: Twin engine GTP project progress thread
    hangover park IL
    no way to be 100% sure. but there arent a whole lot of clutch slippage complaints.
    the problem could likely have come from the vb wear issues. we shall see how this one does.
    are you gonna shim the accumulators? getting the sonnax fixes or see if the low mile vb holds up?
  16. #376 Re: Twin engine GTP project progress thread
    Feb 2009
    flintnasty MI
    Might want to see what sort of mods you can do to get more line pressure. Doubling it is what makes the 65es work.
  17. #377 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    It ran awesome, over 40 runs testing on the street where traction is a big problem and therefore less stress goes on the transmission clutch packs.
    Then 4 runs at the track with high 1.4s 1.5 and 1.6 60 foot.
    It shifted well all gear, never slipped or flared. Ran perfect to be honest. Then when I ran way too much boost off the line it released suddenly as if I had snapped the input shaft or the chain.
    But it basically slammed back in gear. It's as if I had put it in neutral under power then put it back in gear like a neutral drop.
    I wonder if I keep the shifter in the D3 or even D2 position if I reduce the risk of this happening ?
    The other theory is like James said and Dark Horizon said. Not enough pressure. I don't think we had a blockage but I can't rule out some pressure loss in the valve bodies.
    Also maybe the factory pressure isn't nearly enough for over 500ft-lbs of torque. The 4l80e guys who run 800HP have to run 200 psi of line pressure to hold the power. Not enough line pressure the clutch packs can't hold the power.
  18. #378 Re: Twin engine GTP project progress thread
    Nov 2012
    Erlanger, KY
    ^--- My problem was the line pressure was suppose to be double.. and wasn't... and Matt Runs his at 3x the line pressure.
    2001 Turdbo Grand Prix GTP - 10.41@132
    Videos @ https://www.youtube.com/user/jdredd34
  19. #379 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    Quote Originally Posted by jdredd View Post
    I guess that's done with stiffer springs ?
  20. #380 Re: Twin engine GTP project progress thread
    Nov 2012
    Erlanger, KY
    Quote Originally Posted by TwinV6GTP View Post
    Honestly, I am not 100% sure.. it seems getting these to 300psi isn't super hard... but no idea where he gets the 100+ psi from.
    He has no trans cooler. Or at least conventional one that I know of. The stock in/out lines on the bottom of trans just loops to itself. Not sure
    if that assists in removing many feet of line. Either hogged stuff out, stiffer springs, and other unknown valve body tricks, or external electrical pump to boost it?
    With my trans build at TEP dave said it should easily be 300psi or so... and that with the new converter setup, there is no need for 400+ ... so hopefully that works out.
    With some of the stuff dave is doing, and some "secret" things he's got going on, the trans build should take 8's without a problem.. Just need a motor behind it to push
    it that far. Getting well into the 9s is my only goal currently.
  1. Replies: 164
    Last Post: 10-03-2015, 09:07 PM
  2. Replies: 89
    Last Post: 11-20-2012, 11:30 AM
  3. push button start (progress thread)
    By z3r0 in forum Visual/Body Modifications
    Last Post: 12-01-2011, 08:38 PM
  4. my progress thread
    By Dragonblaze in forum Off Topic Discussion
    Last Post: 07-06-2011, 01:26 AM
  5. The new guy: Matto's Project build thread!
    By Matto211 in forum General Tech Discussion
    Last Post: 01-10-2009, 07:47 PM
