Thread: Scangauge II shows 0KR all the time?
Results 1 to 13 of 13
  1. #1 Scangauge II shows 0KR all the time?
    GT Level Member des19's Avatar
    May 2011
    Ontario
    So recently picked up scangauge 2 mainly as a code reader but also for to monitor kr. I noticed that The kr will not read anything never goes past 0 at all at WOT passing, just cruising etc.. It didn't move at all in the 10 minutes i was testing it is this normal to have nk kr whatsoever on an 04 gtp comp g?
    i am overkill tuned, 180 t stat, CAI, msd wires, tr55s, catback.
    is it possible the input pid was input wrong into the scangauge II possibly? will i have to re enter it to set up for kr maybe also anyone know if the 04 gtp protocol would be vpw or cansf? that could be the problem or maybe dont have any kr at all!
  2. #2 Re: Scangauge II shows 0KR all the time?
    antioch ill
    you could have a faulty knock sensor
  3. #3 Re: Scangauge II shows 0KR all the time?
    May 2011
    Ontario
    Quote Originally Posted by Matt Palm View Post
    is that common? seems unlikely
  4. #4 Re: Scangauge II shows 0KR all the time?
    Try tapping on the oil pan and see if it registers anything.
  5. #5 Re: Scangauge II shows 0KR all the time?
    May 2011
    Ontario
    good idea may give this a try and report back tmro!
  6. #6 Re: Scangauge II shows 0KR all the time?
    Banned
    Jan 2013
    Colorado
    you probably didn't program the gauge properly
  7. #7 Re: Scangauge II shows 0KR all the time?
    Feb 2009
    flintnasty MI
    no knock sensor = check engine light.
  8. #8 Re: Scangauge II shows 0KR all the time?
    The Boss Iceman6669's Avatar
    Jun 2011
    That does not work... I tried MANY times and got bubkis
    2011 F-150 Yote powered
  9. #9 Re: Scangauge II shows 0KR all the time?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    ^^^ Hit it harder....
    wait for it.... Who's going to jump first???? LOL
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  10. #10 Re: Scangauge II shows 0KR all the time?
    Hitting the oil pan might not be enough, hit the side of the block or smack the crossover pipe with a hammer. A good smack to the cast iron coil bracket has done it for me aswell.
  11. #11 Re: Scangauge II shows 0KR all the time?
    May 2011
    Ontario
    Lol well the gauge was set up from before so re entered the x gauge for kr. Will see tomorrow if it worked. I now also have a decimal point in the kr reading
  12. #12 Re: Scangauge II shows 0KR all the time?
    May 2011
    Ontario
    little update on this. eventually saw a max of 12 (1.2 KR) on the gauge but does not read this very often also saw 5 (0.5 KR) on the gauge at one point as well. Both was at wot. I re input the xgauge command for gm vehicles and now i have the decimal point (maybe they updated the code) but i havnèt seen a reading on this new input yet LOL so i will report back again haha
  13. #13 Re: Scangauge II shows 0KR all the time?
    May 2011
    Ontario
    with the new code havn;t been able to get it to read KR it shows 0.0 all the time so far. this is the xgauge codes i'm referring to if anyone has a scangauge 2:
    For GM vehicles that use the VPW protocol
    GAUGE TXD RXF RXD MTH NAME Notes
    Elapsed Time Since Engine Start 6C10F12211A1(01) 0462051106A1 3010 000100010000 ET Seconds
    Knock Retard 6C10F12211A6(01) 0462851106A6 3008 002D00320000 KR Degrees
    Barometer V6 6C10F1221251(01) 046285120651 3008 000300010000 BAR Inches of Mercury
    Barometer V8 6C10F122119D(01) 04628511069D 3008 000300010000 BAR Inches of Mercury
    Air to Fuel Ratio 6C10F122119E(01) 04628511069E 3008 000100010000 AFR Ratio
    Remaining Oil Life 6C10F122119F(01) 04628511069F 3008 00C800330000 OLF %
    Engine Torque 6C10F12219DE(01) 0462851906DE 3010 000A00020000 TRQ Ft-Lbs
    Trans Fluid Temperature (Exc Allison) 6C10F1221940(01) 046205190640 3008 00090005FFD8 TFT Degrees Fahrenheit
    Allison Trans Fluid Temperature 6C18F1221940(01) 046205190640 3008 00090005FFD8 TFT Degrees Fahrenheit
    could it be becaue the scangauge isn't version 4.xx its 3.15?
    maybe i should put in the old code not sure where to go from here
    last possibility is its reading correct and i will rarely ever see above 0.0 (which i havn't seen anything above it yet) anyone else rarely see and KR??
  1. 99 GTP dic shows no boost
    By Tspeed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-31-2011, 06:58 PM
  2. Car Shows!
    By Rust in forum The Rant Forum
    Last Post: 09-09-2010, 05:42 PM
  3. 2010 shows
    By blown gt in forum Northeast
    Last Post: 04-17-2010, 07:59 PM
  4. what TV shows?
    By UR LOSN in forum Off Topic Discussion
    Last Post: 03-23-2008, 10:10 AM
