Thread: Does it make sence to add larger fuel injectors on light modded GTP for a HP gain ?
Results 1 to 6 of 6
  1. #1 Does it make sence to add larger fuel injectors on light modded GTP for a HP gain ?
    Feb 2013
    Ohio
    Just curious if you can gain better performance by adding larger fuel injectors. If so does anything else have to be added along with them, like higher volume fuel pump or whatever. Thanks.
  2. #2 Re: Does it make sence to add larger fuel injectors on light modded GTP for a HP gain
    No.
    Click the link in my signature.
    Worthless until you run them static.
  3. #3 Re: Does it make sence to add larger fuel injectors on light modded GTP for a HP gain
    Texas
    Sense....
    85 Corvette
    01 TA
    03 Z06
  4. #4 Re: Does it make sence to add larger fuel injectors on light modded GTP for a HP gain
    GTX Level Member Neil98gt's Avatar
    May 2011
    Kansas city
    Quote Originally Posted by txslow6 View Post
    Sense....
    You beat me to it.
    98 GT 2dr 116k, Sold
    07 Lexus ES350 Obsidian Black. Premium Plus package, sold
    2013 Hyundai Elantra GT
    2002 Grand Prix GT 4dr
  5. #5 Re: Does it make sence to add larger fuel injectors on light modded GTP for a HP gain
    Florida
    the injectors don't have to be completely static to see gains from larger injectors. some injectors have a better spray pattern and mist the fuel better. id say if you are at 85% or more its time to upgrade.
  6. #6 Re: Does it make sence to add larger fuel injectors on light modded GTP for a HP gain
    Feb 2009
    flintnasty MI
    Quote Originally Posted by Z34Phoenix View Post
    115% is a good time to upgrade, assuming you want to push it more.... otherwise why upgrade.
  1. Replies: 39
    Last Post: 08-26-2013, 10:24 AM
  2. WTB: modded fuel rails/logs, and bigger injectors
    By 88formula in forum Wanted To Buy - Parts
    Last Post: 03-20-2013, 02:44 PM
  3. Larger Cam With Larger Rocker Ratio's?
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2009, 02:29 PM
