Thread: Lower control arm mount hole size
Results 1 to 4 of 4
  1. #1 Lower control arm mount hole size
    Jun 2013
    kc
    I have been reading these posts for several years but just joined recently and now have a question. My son had a low speed collision with my 2000 gtp and the lower control arm and steering rack are damaged. Upon removing the lower control arm I noticed the holes in the mounting bracket are elongated or at least larger than the vertical bolt that secures it. Is this normal or did the wreck open up the hole? Thanks for the help.
  2. #2 Re: Lower control arm mount hole size
    St. Louis
    The bolt hole most likely got elongated due to a bad control arm bushing. I wouldn't think it would affect it much.
  3. #3 Re: Lower control arm mount hole size
    Jun 2013
    kc
    Quote Originally Posted by FordMan77 View Post
    Thanks I appreciate your opinion.
  4. #4 Re: Lower control arm mount hole size
    if it was the rear one(horizontal) it'd mess with your alignment and braking. mines elongated at that one in particular unfortunately after 200k+ miles.
  1. How to change lower motor mount and trans mount
    By AlanP in forum How To Write-Ups/Tech Tips
    Last Post: 01-10-2021, 12:39 AM
  2. '98 3.1L lower motor mount, tranny mount replacement help
    By Patrick551 in forum General Tech Discussion
    Last Post: 10-07-2012, 11:37 PM
  3. Lower motor mount...
    By Iceman6669 in forum Brakes/Suspension/Chassis
    Last Post: 04-27-2012, 02:23 PM
  4. What size torx for lower control arm screw
    By nlinesk8s in forum Brakes/Suspension/Chassis
    Last Post: 05-20-2009, 08:38 PM
