Thread: Led bulbs and flasher
Results 1 to 5 of 5
  1. #1 Led bulbs and flasher
    Feb 2013
    Ohio
    I want to swap all my bulbs for led's. superbrightled.com doesn't know if I need new flasher or load things so LEDs work properly. Does anyone have any experience with this issue ? Thanks.
  2. #2 Re: Led bulbs and flasher
    antioch ill
    you only need them for turn signals
  3. #3 Re: Led bulbs and flasher
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    To be honest Iv never tried on a grand prix. Its definately not digital because you get hyperblinker when a bulb is out.... Load resistors always work but flasher modual is a nicer way to do it if possible.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  4. #4 Re: Led bulbs and flasher
    Flasher module is either an EP28 or EP29..
  5. #5 Re: Led bulbs and flasher
    Pennsylvania, USA
    You could do what I'm going to do and just get a small harness extension and wire the resistor in on that, so it's still plug and play in case you need to swap normal bulbs back in.
    Does anyone know if the rear signals need resistors too? I've got an 05 gp. And where to get better prices on switchbacks? I was going to buy them off auto illumination, because I want their crazy bright ones, but damn they're expensive...
  1. flasher relay
    By balt1024 in forum Off Topic Discussion
    Last Post: 10-27-2012, 08:02 AM
  2. 04 flasher location?
    By blknbstd in forum Visual/Body Modifications
    Last Post: 06-11-2011, 03:03 PM
  3. cheap flasher relay?
    By MizzBecca in forum General Tech Discussion
    Last Post: 03-28-2009, 01:44 PM
  4. flasher relay location??
    By David99GTP in forum General Tech Discussion
    Last Post: 10-19-2008, 08:51 PM
