Thread: After clearing codes the sooner light comes on when turning the key
Results 1 to 3 of 3
  1. #1 After clearing codes the sooner light comes on when turning the key
    Mar 2013
    Missouri
    Still working on my pos 01. it wont start; discovered today that after the codes have been cleared after pulling the battery for a while that as so as the key is turned to start the car the sooner light comes on. all car does it crank it still wont fire!
  2. #2 Re: After clearing codes the sooner light comes on when turning the key
    St. Louis
    So from what I read, as soon as you turn the key to start the car the CEL comes back on? All the lights on the dash should come on at initial startup but then go out after the self-test cycle. If the CEL stays on then you need to have it scanned and see what the code is. The car is trying to tell you what the issue is.
    Beyond that, have you verified that you have spark and fuel? Do you hear the fuel pump prime when you turn the key to start?
  3. #3 Re: After clearing codes the sooner light comes on when turning the key
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Check your fuel pressure as you try to start it with a gauge. Autozone rents them. Let us know what it reads
    Pull a plug out, stick the plug back in the wire and ground the threads on the motor mount. Have someone turn the car over and make sure it is sparking. If you don't have spark then could be a bad Crank sensor, ICM, ect....
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  1. Clearing "Service Engine soon" light
    By bvdogg in forum General Tech Discussion
    Last Post: 09-01-2012, 01:14 PM
  2. popping/light banging from rack(?) when turning either way ?
    By reesez in forum Brakes/Suspension/Chassis
    Last Post: 08-25-2012, 10:16 PM
  3. MAF Test and Clearing Codes
    By gobux in forum General Tech Discussion
    Last Post: 06-10-2011, 09:16 PM
  4. It's coming sooner than you think....
    By JESSEGOTTA GP GT in forum Off Topic Discussion
    Last Post: 05-04-2010, 10:51 PM
  5. abs light on = hard turning
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2009, 11:39 PM
