Thread: Heated Seats
Results 1 to 14 of 14
  1. #1 Heated Seats
    Hoffman/Schaumburg, IL
    Hey everyone, I added a factory heated seat to my GT, when I connected the harness from the car to the seat the wires for the heater element were already in the car side of the connector, My question is where are the wires for the switch,
    I think for the 2002's there is only one wiring harness, cause when I added my HUD, the wires were there just plug and play..
    Or if someone has pics of under the dash where the wires from their heated seat switch leads that could be very helpful as well.
    I tried in the other forum, but no one replied w/ info and now that it is -4* in Chicago I think the seat heater would be awesome
  2. #2 Re: Heated Seats
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    if i recall, from what ed morad told me, the harness for the switches is part of the shifter harness in the center console.... so not sure that they'll be there or not.... would be nice if they were
  3. #3 Re: Heated Seats
    Ive looked at the harness, I think it is tucked back in somewhere, thats why I'm hoping that someone has a pic of the wires and where they lead so I can find the other end(from the switch) and trace my way to the connector... a wireing diagram may help to,
    thanks to everybody for any help they can give(including thanks to you toasty)
  4. #4 Re: Heated Seats
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    Toasty is the man, this is fact. haha. I will see next time I have one in the shop if I can get a pic of this for ya.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  5. #5 Re: Heated Seats
    thanks
  6. #6 Re: Heated Seats
    SW Chicago Suburbs
    here's the console harness routing, hope this helps...
    Heated Seats Attached Images
  7. #7 Re: Heated Seats
    Topeka, KS
    are you adding the passenger seat heater? If so you splice into the wiring under the drivers seat. Should be some kind of plug for the heater to my understanding.
  8. #8 Re: Heated Seats
    SW Chicago Suburbs
    Here's the pinout for the console harness pictured above... this is #6, C240. provided that all of the wires are there on the car side, if you are missing some on the console side, a proper console harness should get you up and running. (if it is not hidden somewhere, like it might be)
  9. #9 Re: Heated Seats
    thanks very much, Ill ask Ed if he has that harness, cause that one is in my car but missing the extra extension....
    is that for the 97-00 since it has the perf shift button, or since they left the wires there is it the same 97 - 03....My car is 02 if that helps, sorry to ask so many ?? but i want to be sure before I go buy stuff or start cutting and splicing wires
  10. #10 Re: Heated Seats
    SW Chicago Suburbs
    Quote Originally Posted by 02BlueGT View Post
    eh, yeah that's from the manual for my 97. if you want to verify what's what, compare the pinout i posted to the wire colors in yours.
    -- check the car side of that harness, see what wires are there that do not have a mate on the console side. those should be for the heated seat switch...
    i'll look and see what i have as far as an actual wiring diagram/connector info, but you should actually be able to just add a few pins in that connector i posted, along with the seat switch, and the wires down to the seat and be good to go...
    now wouldnt it have been nice if the elements, etc were in the car too, just not hooked up... heh
  11. #11 Re: Heated Seats
    yeah that would be nice, when I had the dash apart, I looked at that connector and all the wires seemed to be there so maybe they just dead end there, cause I would hate to have to tear apart the wiring harness and start cutting and splicing
  12. #12 Re: Heated Seats
    SW Chicago Suburbs
    well, i did some looking. the heated seat switch pulls a few wires from the main connector up at the front of the console, but the 2 wires that come out of the switch and go back into the harness come out at # 4 on that harness diagram i posted earlier. is something plugged into the #4 spot already on your car or no?
    the biggest thing is that the heated seat switch connector (6 way) is NOT available to buy on it's own, unless you buy 650 of them..
    you'll likely be best off getting ahold of Ed Morad and getting the console harness for heated seat switch, and the switch. he should be able to get you what you need.
  13. #13 Re: Heated Seats
    yeah good ol' ed is there anything he doesn't have(for our cars)
  14. #14 Re: Heated Seats
    Saraland Alabama
    yeah the air bag coil for the drivers side (although he has tried)
  1. thinking about switching to 06 monte ss seats
    By s1795so2 in forum Visual/Body Modifications
    Last Post: 01-06-2008, 01:29 AM
