Thread: Short Ram Intake, Fender Well Intake, Etc.?
Results 1 to 14 of 14
  1. #1 Short Ram Intake, Fender Well Intake, Etc.?
    GT Level Member Pokealong1227's Avatar
    Oct 2012
    Oak Grove, MO
    I currently have a Spectre oiled filter hooked up to my MAF sensor tube for a short ram intake. It runs and sounds amazing. Much better than stock, no doubt about it. I also have a foot of intake tubing(4" with clamps) so I COULD move the filter around if I wanted. Would it be benefical to make a fender well intake or move the filter at all? Or is it fine where it is? I don't race or anything, just enjoy modding for myself. So a quarter mile time isn't a huge deal for me. I would like the best throttle response and full range of power. What are your opinions? Some pictures would be great too if you think something other than a short intake would be better.
  2. #2 Re: Short Ram Intake, Fender Well Intake, Etc.?
    I live here. TLSheff's Avatar
    Being N/A you would want to get as cool of air as possible.
  3. #3 Re: Short Ram Intake, Fender Well Intake, Etc.?
    Likely you have done something similar to these... http://www.grandprixforums.net/spect...get-78057.html
    Which is simple and functional for most, but for NA I would suggest going the extra mile and pushing for something like this is you are interested...http://www.grandprixforums.net/make-...ke-fwi-20.html
    Quote Originally Posted by GeddyLee View Post
    When I made my similar fender well intake setup. I actually moved my AIT sensor down to where the hole in the fender well was and tapped into the PVC there for the sensor intake readings.
    Here is a picture of mine when I did have it in there. I cut through the flashing to get to the tap I created and Gorilla glued a rubber gromet into the PVC so I could remove the sensor without issue when necessary.
    or
    Quote Originally Posted by jshifti33 View Post
    After doing my intake I found that the instructions were lacking a few details. Here are some things that may make it easier to make the intake.
    1. I used white lithium grease to help the PVC pipe fit onto the rubber elbows.
    2. A 1/2 inch drill bit works perfect for making the hole in the intake that air sensor plugs into.
    3. When I got my PVC pipe I could only get it in a 10 foot length. I got mine at Men@rds and even though it was 10 feet in length it was still only $7.00.
    4. I used a 12" conical air filter so I had to modify the instructions slightly. 14" for the longest piece, two 45 degree elbows, and a second 3 inch section.
    I hope this helps anyone else who is thinking of doing this. With this communities help and little elbow grease its amazing what you can do.
  4. #4 Re: Short Ram Intake, Fender Well Intake, Etc.?
    May 2008
    Schuyler, NE
    It is my opinion that you want some straight pipe before the MAF on the 04+ cars. I think it helps the MAF to get a more accurate reading. But, that is a completely untested theory.
  5. #5 Re: Short Ram Intake, Fender Well Intake, Etc.?
    OP's profile shows a 2003 GT
  6. #6 Re: Short Ram Intake, Fender Well Intake, Etc.?
    Oct 2012
    Oak Grove, MO
    Very informative with good intake and pictures. So going with a closed off fenderwell intake would be the best set up for a NA car? I will look into that. Thanks!
  7. #7 Re: Short Ram Intake, Fender Well Intake, Etc.?
    May 2008
    Schuyler, NE
    Didn't look at that. Just figured that since he was talking about a MAF housing, he must have an 04+.
  8. #8 Re: Short Ram Intake, Fender Well Intake, Etc.?
    mine ran better after I hooked about 6" of pvc in between the maf and filter instead of just having the filter off the maf.
  9. #9 Re: Short Ram Intake, Fender Well Intake, Etc.?
    May 2008
    Schuyler, NE
    When someone says, "Mine ran better after I did ......", I usually don't take them seriously.
  10. #10 Re: Short Ram Intake, Fender Well Intake, Etc.?
    ^ LOL, right!
    You referring to the 98 or your new one, when you say mine?
    We have established a general consensus that with boosted cars more air > restricted cold air, but not being boosted should get as cold of air as possible. Short rams work to get more air in, but its still only going to suck in as much as the motor and suck lol, sounded dirty But its true, the big difference is the cooler denser air.
    Just up to the owner, how you want to run it.
  11. #11 Re: Short Ram Intake, Fender Well Intake, Etc.?
    Taking about my comp g. It quit bogging taking off
  12. #12 Re: Short Ram Intake, Fender Well Intake, Etc.?
    May 2008
    Schuyler, NE
  13. #13 Re: Short Ram Intake, Fender Well Intake, Etc.?
    Jersey
    i don't understand the whole pvc intakes
    16' wrx sti- stock
  14. #14 Re: Short Ram Intake, Fender Well Intake, Etc.?
    May 2008
    Schuyler, NE
    Functional, but wow...they look like poop.
  1. Fender intake
    By JT2002GTP in forum General Tech Discussion
    Last Post: 05-03-2013, 02:13 PM
  2. Short Ram Intake
    By sirricealot in forum 5.3L V8 (LS4)
    Last Post: 12-06-2012, 11:49 AM
  3. Short Ram Air intake or Cold Air Intake
    By slopez in forum General Tech Discussion
    Last Post: 02-01-2011, 10:08 PM
  4. Short ram intake. Done!
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 07-12-2010, 08:33 PM
  5. short ram intake
    By digilue in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-29-2008, 04:08 AM
