Thread: check gas cap '05 gtp
Results 1 to 5 of 5
  1. #1 check gas cap '05 gtp
    SE Level Member carr08's Avatar
    Mar 2012
    Northwest Ohio
    A couple days ago i got into my car and i got the "check gas cap" on the display. so i did what it told me to and checked it. i unscrewed it and then screwed it back in but nothing changed. i've checked it out online and most people say it could either be as simple as the gas cap or the EVAP solenoid canister. i'm sure other people have had this problem so i figured i'd see what everyone else started off with.
    2005 grand prix gtp w/ k&n cold air intake
  2. #2 Re: check gas cap '05 gtp
    try a new gas cap first.
    is the cel on? of so have it scanned. the code will tell more.
  3. #3 Re: check gas cap '05 gtp
    GT Level Member GP Guy 07's Avatar
    Feb 2013
    Elgin
    Getting it scanned will give you a better idea on whats going on.Then once you find out,you won't waste money on the wrong part.Anymore problems just ask.
    07 GP black on black,SPO spoiler,grills,hai,aftermarket rims,Led tails,drilled+slotted rotors
  4. #4 Re: check gas cap '05 gtp
    Donating Users gmoney's Avatar
    Buffalo, NY
    I got this same message yesterday in my '04. Same thing, checked it, unscrewed it and screwed it back on, even had to fill up. Still getting it. No CEL, just the DIC message. I'm going to try replacing the cap. Does anyone make one that tethers to the car the way the original did? Dealership?
  5. #5 Re: check gas cap '05 gtp
    ive heard of people greasing the rubber part of the cap that seals to the fill tube on the car. if it still says check gas cap, it could be the vent in the gas cap is bad. or a evap leak.
  1. Check this out
    By Below Average Joe in forum Off Topic Discussion
    Last Post: 12-02-2011, 11:39 AM
  2. Check out this GXP I want to buy
    By Durk Diggler in forum Off Topic Discussion
    Last Post: 11-14-2011, 01:41 AM
  3. check it...
    By dpzelenak in forum Off Topic Discussion
    Last Post: 02-16-2011, 08:15 PM
  4. Check it out!
    By Nickell in forum Visual/Body Modifications
    Last Post: 10-26-2009, 02:32 PM
  5. a few o2 DTC's..what should i check first?
    By kyle99gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2009, 08:50 PM
