Thread: HVAC vents not changing
Results 1 to 5 of 5
Jakegday HVAC vents not changing 05-26-2013, 12:57 PM
Jakegday Re: HVAC vents not changing 05-27-2013, 10:21 AM
Jakegday Re: HVAC vents not changing 05-27-2013, 02:07 PM
BillBoost37 Re: HVAC vents not changing 05-28-2013, 06:06 AM
Explicit_Spade Re: HVAC vents not changing 05-28-2013, 06:12 AM
  1. #1 HVAC vents not changing
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    hey guys. went to use my A/C last night when i noticed the MAX A/c wasnt working. It would blow cold air, but it would not go into recirculate mode. Then after that i noticed air just came out of the front vents only, no matter what position the switch was in (floor, vent, defrost) The switch still makes the a/c compressor kick on when its switched to max a/c or defrost, but the vent position doesnt change. I checked all vacuum hoses under the hood and everything looks fine, (although i couldnt find one specifically that goes right into the HVAC unit) I paid special attention to the areas around the spark plugs and wires i recently changed, but couldnt find anything suspicious.
    Any suggestions on where to start?
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  2. #2 Re: HVAC vents not changing
    Nov 2008
    Fremont Nebraska
    can anyone at least tell me where under my hood i would find the vacuum line that goes to the HVAC unit??
  3. #3 Re: HVAC vents not changing
    Nov 2008
    Fremont Nebraska
    NEVERMIND. Just found the vacuum line i was asking about. apparently it runs near the battery, where it joins a wiring harness that then goes through the bulkhead (firewall). because of this, its in the perfect spot for corrosion from the battery to fall/drip on to the line and cause it to corrode/melt.
  4. #4 Re: HVAC vents not changing
    Uh what...plastic/rubber shouldn't corrode
  5. #5 Re: HVAC vents not changing
    Omaha, NE
    Nebraskans...
  1. A/C vents and boost
    By charlie31603 in forum General Grand Prix Discussion
    Last Post: 11-30-2012, 10:50 AM
  2. Vents issue
    By Camambro in forum General Tech Discussion
    Last Post: 09-24-2012, 02:59 PM
  3. Will Dual HVAC Work in Stock HVAC
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 11-25-2010, 10:57 PM
  4. Window Vents
    By Egleone6 in forum Visual/Body Modifications
    Last Post: 09-03-2008, 08:34 AM
