Thread: Another ABS/Trac/Cruise question
Results 1 to 2 of 2
  1. #1 Another ABS/Trac/Cruise question
    SE Level Member jamez74's Avatar
    Jan 2013
    Medicine Hat, Alberta
    When I bought my car the trac control never worked at all. The ABS light was not on but after checking that I noticed the previous owner had unplugged the light so that's on . Also my cruise would only work intermittently. I recently read somewhere that someone else having problems with there cruise unplugged the EBCM and the problem went away. I decided to try that and it worked!
    Now my question is, due to that, does that mean that its a bad ECBM or could it still be a bad wheel bearing? Its not a broken/bad wire as all wheel bearings had voltage at the plugs. I would really rather not have to get it scanned at the stealership but I think I may have no choice. The Trac off light is ALWAYS on, have never seen it flicker or go on at all.
  2. #2 Re: Another ABS/Trac/Cruise question
    most garages will charge less then a dealer. you can also buy a hand held abs scanner for under a 100.
  1. 1992 Grand Prix LE Cruise Control question
    By verlando in forum General Grand Prix Discussion
    Last Post: 09-12-2012, 08:14 AM
  2. ABS/Low Trac
    By Below Average Joe in forum General Grand Prix Discussion
    Last Post: 06-14-2012, 10:32 AM
  3. Cruise control question
    By Cobras 98 Prix in forum General Tech Discussion
    Last Post: 07-20-2011, 03:04 PM
  4. 2001 grand prix cruise control question
    By Old Pontiac Man in forum Audio, Security & Visual Electronics
    Last Post: 01-30-2011, 09:09 AM
  5. TRAC Off
    By tdm571 in forum General Tech Discussion
    Last Post: 12-28-2010, 02:22 PM
