Thread: E85
Results 1 to 5 of 5
  1. #1 E85
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    Would it be safe to run E85 on a stock fuel system? Or could I do a blend with 93 and E85?
  2. #2 Re: E85
    GTX Level Member cerick08GP's Avatar
    IMHO, yes it would be safe. E85 shouldn’t damage your fuel system or engine, if you car is in good repair. IIRC in the 80’s car fuel systems were changed to deal with ethanol. And then about 97 the whole E85 thing exploded, and to my knowledge the big difference between an E85 car and not, is a sensor and an extra injector map (my terminology might be off I’m not a tuner guy). I also have read accounts of many people running E85 with zero mods, and no problems. That said, you might run out of injector duty cycle if you driver it like a race-kar.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: E85
    Ohio
    You need tuned for it.
    You need larger injectors.
    Run one or the other. Don't do half and half. Run the tank low, fill up with the opposite and switch to that fuels tune.
    You'll want to change your fuel filter a time or two afterwards.
  4. #4 Re: E85
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    I run e85 and i love it. Never had to change the filter on mine or my buddies car.... We must have clean gas here
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  5. #5 Re: E85
    Feb 2009
    flintnasty MI
    Quote Originally Posted by MoarkatsINmuhtrailer View Post
    With a stock pulley you could probably run it without tuning if you took it easy for the first few miles. would need to keep an eye on wide open stuff, tuning would help alot.
e85
