Thread: Radio Station-Clock window does not illuminate
Results 1 to 15 of 15
  1. #1 Radio Station-Clock window does not illuminate
    May 2012
    Jacksonville, Fl
    The radio and CD in my 02 GP GT works like a champ as far as the sound goes. The problem is the window that tells me what station I have the radio on or what time it is does not illuminate. Can the display window be repaired or replaced or is it all part of the radio unit? Is this something the dealer has to replace or can I take the unit out and send it off to be repaired or replaced and reinstall it without knowing some secret code? Thanks in advance, Bill
  2. #2 Re: Radio Station-Clock window does not illuminate
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    Could be as simple as a blown bulb. Not sure how to get to it, but I'm pretty sure I've seen the method somewhere on one of the forum threads. Click the little magnifying glass at the top centre and search away.
  3. #3 Re: Radio Station-Clock window does not illuminate
    St. Louis
    There is a small bulb that backlights the display and they are known to go out. GM dealer has them. If you can't find it via search then I'll look when I get back from vacation tomorrow night as I've done it to my 00 GT before. Yes, you will have to take the radio apart but it's not hard.
  4. #4 Re: Radio Station-Clock window does not illuminate
    If you want to buy a complete radio i have one that works fine
  5. #5 Re: Radio Station-Clock window does not illuminate
    Bill.. just based on it being an 02 w/o radio display.. lemme guess, it's a blue car isn't it?
    You need the display bulb or a radio.
    Pontiac Delco Radio LCD Display Light Bulb CD CAS | eBay
  6. #6 Re: Radio Station-Clock window does not illuminate
    May 2012
    Jacksonville, Fl
    Actually it is a white car with tan interior.
    I sure hope it is the display bulb since many times I drive from Fl to Tx or Fl to DC without even turning the radio on but I sure miss the clock.
  7. #7 Re: Radio Station-Clock window does not illuminate
    May 2012
    Jacksonville, Fl
    Quote Originally Posted by FordMan77 View Post
    Any assistance in helping me pull the radio out without busting up the dash will be greatly appreciated. Along with what I need to do to get the clock lit up again. Thanks
  8. #8 Re: Radio Station-Clock window does not illuminate
    Jun 2013
    Ohio
    I am watching for advice on this too for my 02. I read the thread with pics for replacing the bulb in an 04+ but wondering how similar it would be.
    dsmuts - what year is your radio from and how much if you are still selling? I'm in the Toledo area - thanks.
  9. #9 Re: Radio Station-Clock window does not illuminate
    Aug 2011
    'Merica
    My 03 did this too...but I did not care since the radio/cd player still worked. I set my stations so I knew what stations were on each number button.
  10. #10 Re: Radio Station-Clock window does not illuminate
    Mine is from a 99 I had it in my 98
  11. #11 Re: Radio Station-Clock window does not illuminate
    97-03 grab the dash surround piece. I find it's easiest to get my fingers in around the cluster or the pockets to the side of the wheel. Pull and the clips will release. Then unhook the fog light connector from the switch. now you can set that dash surround aside.
    3 7mm screws hold the radio in.. unplug the antenna and connector(s).
    Opening the radio.. looking at the radio face, unhook where the plastic pieces are hooked. one is bent up..bend that in..and unhook the rest.. wiggle gently and the face will pull out. change your bulb by turning counter clockwise to remove and clockwise to put back in.
    Slide face back together, put back in dash after connecting and then push the surround back on after hooking up the fog connector.
  12. #12 Re: Radio Station-Clock window does not illuminate
    May 2012
    Jacksonville, Fl
    Thank You Kind Sir, I think I can follow those instructions and hopefully the clock will be back working again !
  13. #13 Re: Radio Station-Clock window does not illuminate
    Dec 2012
    Where 4T65E's were born
    Oh, and don't forget the two screws on the bottom of that piece. Remove those first. They are a small size but mine have a Phillips head as well. I actually made a video on how to remove the radio and take it apart, just didn't bother to edit and upload it.
    Sold.
  14. #14 Re: Radio Station-Clock window does not illuminate
    Jun 2013
    Ohio
    Thanks guys. And I would love to see that video NavyBlue, I don't work on cars much and would find that comforting before I mess mine up!
  15. #15 Re: Radio Station-Clock window does not illuminate
    Dec 2012
    Yeah I've been pretty busy lately, I don't think I could get it done before you'd want to fix your radio. Bill's description was pretty good, the whole thing after the screws really does just pull right off, there are metal clips holding it on. Everything with removing the radio is really self explanatory.
    Sold.
  1. Radio clock wont display?
    By jayroca in forum Audio, Security & Visual Electronics
    Last Post: 03-24-2013, 05:23 PM
  2. Gas station lady wants to trade for my GTP
    By McCoyH in forum General Grand Prix Discussion
    Last Post: 04-27-2012, 11:58 PM
  3. 1996 Pontiac Grand Prix SE radio/clock display
    By moospis in forum General Tech Discussion
    Last Post: 08-03-2011, 03:58 PM
  4. OEM Radio Clock stays on?
    By 100 BUX in forum General Tech Discussion
    Last Post: 03-16-2009, 01:58 PM
