Thread: Tap shift not working?
Results 1 to 10 of 10
  1. #1 Tap shift not working?
    SE Level Member hcokiid18's Avatar
    May 2011
    Dayton, Ohio
    I have an 04 GTP Comg G. I didn't know it was the comp g. until I seen the Competition Group under my GTP badges and heard comp g only has the tap shift - which I have. I put the gear into "M" but nothing different changes? it still shifts by its self. I notice when I do put it into "M" it says "3" on the display screen.. Hmm, I don't quite understand? I also heard if the fuse is bad my cruise wouldn't work either but it does - bummer... Any suggestions on how to activate/fix this problem? My trans shifts great so my trans is fine..??
    04 GTP Comp G. 3.4'' Pulley, Pace setters, 180*STAT, Tuned,Slotted Rotors,Thrasher Intake, 152k
  2. #2 Re: Tap shift not working?
    GT Level Member 04BlackComp_G's Avatar
    Apr 2008
    Rockport, ME
    Usually cruising around under 40-45 your car will stay in 3rd. At least that's what mine does. Try shifting through all the gears from a stop and see what happens. Also the transmission is electronically controlled no matter if you have it in D or M so if you get to the shifting point and don't shift, it will do it for you. That way you don't bounce off of the rev limiter.
    2009 G8 GT #1311 of 1949:CTS-V front/Camaro rear brakes, Solo Performance axle back exhaust
    2006 GP GXP: ZZP catback, k&n intake, retrofit headlights, cts-v brakes
    2007 Escalade ESV:family hauler
  3. #3 Re: Tap shift not working?
    GT Level Member GMCustomerService's Avatar
    Michigan
    @hcokiid18, I have read your post about the tap shift in your 2004 Grand Prix. Would you mind sending me a private message with your VIN? I would like to do some research about this for you to include looking into your build sheet information and things like that.
    Michelle, GM Customer Service
  4. #4 Re: Tap shift not working?
    May 2011
    Dayton, Ohio
    That didnt help any.. Still doesn't work, I dont get it
  5. #5 Re: Tap shift not working?
    canada
    My tap shift is also not working. Same vehicle - 04 gtp competition. Also, I'll be driving along in auto > 80 km and if I let off the gas, it feels like it's shifting down. The car jolts as it tries to slow and the RPM are sent roaring. Now it seems like this problem began around the time the battery died, which we charged a couple of times, then replaced. Not sure if there is any connection or not. Help?!
  6. #6 Re: Tap shift not working?
    Pennsylvania, USA
    Honestly, tap shift is just a gimmick on these cars. The PCM knows the best point to shift, tap shift is exactly the same as shifting between gears with a normal shifter column. The car will over ride both when it needs to, I only use my shifter on hills where the car insists on upshifting, only to downshift a minute later.
  7. #7 Re: Tap shift not working?
    May 2012
    Where winter never ends
    Ahh! Zombie Thread! Get the shotgun!
    (You guys do realize this thread is over two years old? lol)
    2000 Regal - Winter Beater
  8. #8 Re: Tap shift not working?
    GTP Level Member rodguezsciii's Avatar
    Sep 2012
    when engaged, the pcm should not be able to take over and upshift.....if you reach too high of a speed/rpm you should hear a loud chime, the pcm is supposed to limit your speed to protect the trans, but once again should not upshift for you....now it'll downshift for you when coming to a stop, but that's it....you can also start out in 2nd gear from a dead stop....and be able to throw it into Tap Shift even while driving, which is the only time it really can help say you want to downshift and take off....but with 4 gears the fun is limited....
  9. #9 Re: Tap shift not working?
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    Mine just bounces off the rev limiter... it only downshifts to 1st at under 10mph. Never once has it upshifted for me...
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  10. #10 Re: Tap shift not working?
    Mine slips in tap shift but not otherwise
  1. Tap shift Stopped working
    By dlemmen in forum General Tech Discussion
    Last Post: 06-16-2011, 07:29 PM
  2. Performance shift not working?
    By Fierogtfreak in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2011, 05:18 PM
  3. perf shift not working (not the button)
    By lisas1998gtp in forum General Tech Discussion
    Last Post: 04-23-2010, 10:55 PM
  4. site working and then not working etc.
    By Rocket468 in forum Site/Club News
    Last Post: 03-24-2010, 11:53 PM
  5. Performance Shift Not Working
    By bstith in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-18-2009, 06:05 PM
