Thread: Emergency brake light always on
Results 1 to 8 of 8
  1. #1 Emergency brake light always on
    Apr 2013
    Ohio
    I bought a 99 GTP from the original owner about a month ago. It has 110000 on it. I noticed that starting last week, the emergency brake light comes on and stays on most of the time while driving. I have made sure the pedal is fully released. The brake still works fine when I need it. Anyone have this problem? Solution? Thanks in advance!
  2. #2 Re: Emergency brake light always on
    Is the brake fluid full?
  3. #3 Re: Emergency brake light always on
    SWPA
    ^ That. If the brake fluid gets low in the resevoir it will trigger the brake light.
  4. #4 Re: Emergency brake light always on
    Apr 2013
    Ohio
    Didn't think of that. I'll check it out in the morning. Thanks
  5. #5 Re: Emergency brake light always on
    Apr 2013
    Ohio
    Fluid looks a little low. A little below the mid-line of the reservoir. The max line looks to be at about 3/4 full. I am going to pick some up tomorrow and hopefully that'll fix it!
  6. #6 Re: Emergency brake light always on
    SWPA
    You probably need to check your brake pads while you are at it. Pads getting low will be the main cause for fluid being low, unless there is a leak of course.
  7. #7 Re: Emergency brake light always on
    If thats not it, then you'll have to look deeper into the issue.
    Like wiring and or a sensor issue.
  8. #8 Re: Emergency brake light always on
    GT Level Member thegipper's Avatar
    grafton, wi
    Mine would periodically go on and it was because the brake fluid was a little low. Fill her up and be done with it =)
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  1. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  2. Seized Emergency Brake, NoIcon Displayed
    By grandprixgtp2001 in forum Brakes/Suspension/Chassis
    Last Post: 12-23-2011, 10:49 AM
  3. Remount Emergency Brake
    By 96GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 12-31-2010, 09:50 PM
  4. Emergency brake gone
    By BlackJack in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 08:49 PM
