Thread: Hvac Nightmare
Results 1 to 8 of 8
  1. #1 Hvac Nightmare
    SE Level Member sdogg201's Avatar
    Mar 2012
    Saginaw
    SO I am having an issue with my outside temp reading way to low. I have changed the ambient temp sensor 2 times now and changed my control unit with one that I know works for sure (pulled it out of my friends car gives me the same reading. if it's 80 outside it reads 21 degrees. I have checked the connections and ran the diagnostics through the control unit no errors. Also when I unplug the temp sensor it throws an open connection code so the wiring is good. Any ideas ???
  2. #2 Re: Hvac Nightmare
    try your friends air temp sensor.
  3. #3 Re: Hvac Nightmare
    Mar 2012
    Saginaw
    unfortunately he is not around for a few days going back to autozone and going to get another one tomorrow after work.
  4. #4 Re: Hvac Nightmare
    Mar 2012
    Saginaw
    Going to go through the the wiring one by one I suppose and see if something is grounding out.
  5. #5 Re: Hvac Nightmare
    Check the wiring to the external sensor. I had an issue with this myself and found that something had caused the wire to break internally and caused it to read extremely low. The sensor itself ended up being good.
  6. #6 Re: Hvac Nightmare
    Mar 2012
    Saginaw
    Will do thanks bill I think I might just rewire the whole think today and pray for the best
  7. #7 Re: Hvac Nightmare
    Or you could unplug the one on the car.. tap in near the HVAC and see if that fixes the reading. if so.. trace it out/rewire it.
  8. #8 Re: Hvac Nightmare
    Mar 2012
    Saginaw
    ok so I found a black wire that was plugged inline with a small connector. unplugged it and temp reads right. now AC clutch not engaging off to test voltage lol
  1. Electrical Nightmare
    By black97GT in forum General Grand Prix Discussion
    Last Post: 03-30-2013, 01:12 PM
  2. Need serious advice about my nightmare car
    By kwk6564 in forum General Tech Discussion
    Last Post: 08-14-2012, 06:54 AM
  3. copper nightmare
    By thomas mcnulty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-21-2012, 06:36 PM
  4. Is it an electrical nightmare?
    By h0wl0ngcanitbe in forum General Tech Discussion
    Last Post: 01-10-2011, 08:40 PM
  5. Will Dual HVAC Work in Stock HVAC
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 11-25-2010, 10:57 PM
