Thread: 01 grand prix gt ....Need help tranny problems
Results 1 to 11 of 11
  1. #1 01 grand prix gt ....Need help tranny problems
    Mar 2012
    Michigan
    I get one thing fixed and now I have another problem, took my 01 3.8L it has 139,000 miles on it ( not super charged) to get it fixed in the shop and they are telling me that it is my transmission, I hear this noise come from it when I shift from park to drive sometimes not all the time or when I come to a complete stop and then go,it sounds almost like a tie rod going but those have already been replaced and I can feel it sometimes on the floor, does anyone know what it might be. But it doesn't do it when it is raining out, it only does it when it is on dry pavement
    sammie
  2. #2 Re: 01 grand prix gt ....Need help tranny problems
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Have upper motor mounts and bushings checked....and the big typical failure is going to be the hydraulic motor mount and transmission mount. Rule all of those out of the equation first. 90% of the times it's either a motor/trans mount that's failing.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  3. #3 Re: 01 grand prix gt ....Need help tranny problems
    Mar 2012
    Michigan
    Had new tranny, bottom and top mounts replaced already,noise is still there
  4. #4 Re: 01 grand prix gt ....Need help tranny problems
    Mar 2012
    Michigan
    Just put in a new rack n pinion and power steering pump and noise is still there
  5. #5 Re: 01 grand prix gt ....Need help tranny problems
    I've heard my strut mounts complaining most of the times you are describing, unfotunately you don't describe the noise, only that you hear it. Hear what Sammie, you gotta describe it..because we aren't there to hear it.
    As for the shop saying your trans was bad, is this just based on the noise?
  6. #6 Re: 01 grand prix gt ....Need help tranny problems
    Mar 2012
    Michigan
    Ok, sorry the best way I can descibe it is when I am at a stop sign and go to turn left, that is when I hear the noise,it sounds just like a tie rod when it starts to go bad and when I shift the car from park to drive sometimes it does it,but only on dry pavement, not when it is raining out. But I can feel it from the bottom of my floor on the driver side,it feels like it is coming from my left front tire.
  7. #7 Re: 01 grand prix gt ....Need help tranny problems
    Sammie.. I've never had a tie rod make a noise, only get sloppy. Please describe the noise.
  8. #8 Re: 01 grand prix gt ....Need help tranny problems
    Nov 2012
    Frederick, MD
    Check to see if the sway bar or the sway bar link is broken.
  9. #9 Re: 01 grand prix gt ....Need help tranny problems
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    Maybe the axle....
  10. #10 Re: 01 grand prix gt ....Need help tranny problems
    GT Level Member thegipper's Avatar
    grafton, wi
    I agree with Bill, you have to describe the noise for us to try to better diagnose the problem. Does it sound like a popping noise?
    I had a "popping" noise coming from the front end. Thought for sure it was a control arm bushing, end link, or ball joint. Checked/replaced most of those things and it still made the noise. Mounts were all good. Finally bit the bullet and took it to my local mechanic. It was the strut tower mounts were shot. When I would accelerate from a stop or come to a stop it would make a popping noise. Sometimes you would hear the noise when turning or hitting a bump.
    Moral of the story, do a better job describing the problem and we will have a better chance of being able to help you.
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  11. #11 Re: 01 grand prix gt ....Need help tranny problems
    Mar 2012
    Michigan
    Found the problem, it was a defective outer tie rod.Thank you all for helping me
    Sammie
  1. 2007 grand prix gt tranny problems!! Need some feedback! ASAP
    By Chavis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-10-2013, 11:01 PM
  2. 2001 Grand Prix tranny
    By Bowtie01 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-15-2013, 06:19 AM
  3. 01 Grand Prix GTP with tranny issues
    By Sweetser in forum Introductions/Noob Questions
    Last Post: 02-07-2011, 11:12 AM
