Thread: parking lights stay on
Results 1 to 5 of 5
  1. #1 parking lights stay on
    May 2013
    Kansas
    Hello all. Hopefully someone has had this happen before and can help me. I recently washed down the engine due to a hose blown. Now the parking lights stay on and drain the battery down. There is power to the fog lights as well but I can turn them off with the switch. The inside bell goes of when you remove the keys like the lights are left on but the switch is off, headlights off but park lights remain on. I removed the fuse under the hood to disable the lights and keep the car drivable. The headlights work fine. The bell still dings every time you open the door. I tried removing relays etc..but so far I'm stumped. Anyone??
  2. #2 Re: parking lights stay on
    By the dinging, the switch and BCM are seeing power. Are these your original lights or have they been swapped?
  3. #3 Re: parking lights stay on
    May 2013
    Kansas
    They were swapped out a couple years ago but they are aftermarket original replacements.
  4. #4 Re: parking lights stay on
    That rules out oddities with the harnesses.
    Know anyone local you could swap a headlight switch with?
  5. #5 Re: parking lights stay on
    May 2013
    Kansas
    I unplugged the headlight switch from behind and nothing changed. Didnt want to buy a new switch if that wasnt what was wrong.
  1. interior lights stay on after getting in.
    By ls1racer11 in forum General Tech Discussion
    Last Post: 08-28-2014, 12:50 AM
  2. Replies: 3
    Last Post: 01-16-2010, 07:19 PM
  3. 06 lights won't stay on
    By cooney in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-27-2009, 07:25 AM
  4. Just parking lights?
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 09-01-2008, 01:24 PM
